How to display filter based on category of product?
oliwin4
Post by oliwin4 » 24 Aug 2022, 20:18
I need to show dinamic filters based current category of product. How do do that and manage it?
Re: How to display filter based on category of product?
Post by aimeos » 26 Aug 2022, 10:08
By default, filters which are not available for the current category are hidden via CSS and enabled by JS:
https://github.com/aimeos/ai-client-htm ... #L213-L218
oliwin4
Post by oliwin4 » 29 Aug 2022, 21:07
Could I manage it in Admin panel? For example create a custom filter for tree categories?
Post by aimeos » 31 Aug 2022, 07:06
It would be possible to assign attribute types to categories via the mshop_catalog_list table and use them in the frontend to determine what filters should be shown. For that, you have to create your own subpart for the category tree panel where you can assign the attribute types and you have to change the frontend code to use that attribute types.
