Pattern matching in search/filter
kartikbhat
Post by kartikbhat » 30 Aug 2022, 15:48
I need to change filter/search term "==" to "%LIKE%" kind of pattern matching while query;
Here I have comparison with "==" operator on themes field of products table
$products = \Aimeos\Controller\Frontend::create( $context, 'product' )
				->sort( $sort ) // prioritize user sorting over the sorting through relevance and category
				->compare( '==', 'themes', $view->param( 'f_theme' ) )
I need to make this thing should work with %LIKE% kind of pattern (substring/subpart of value present at theme field of products table)
How can I modify above code to work it properly...
TIA :)
Re: Pattern matching in search/filter
Post by aimeos » 01 Sep 2022, 10:57
