Extending base template view from the package folder
pamirsawar
Post by pamirsawar » 06 Sep 2022, 05:53
Hello aimeos!
I've created a new extension through but some views files are not extending from the package folder.
for example base.blade.php and jqadm/index.blade.php.
But I am able to override these templates after I put them into the resource/views/vendor/shop folder.
Is this a bug or does it not configured properly for me?
I want to extend base.blade.php view but only for that extension/theme.
aimeos-laravel: 2022.07.2
windows 10
php 8.1
Re: Extending base template view from the package folder
Post by aimeos » 07 Sep 2022, 16:09
The jqadm/index.blade.php file cannot be theme specific because the backend doesn't support different themes per site. You can only overwrite it once in the resources/views/vendor/shop/jqadm/index.blade.php folder.
The resources/views/vendor/shop/base.blade.php can be overwritten by several themes and you can select the theme in the admin backend for each site. Just make sure that your other Blade files in the theme (resources/views/vendor/shop/catalog/* Blade templates for example) extend from your base.blade.php file in that theme.
pamirsawar
Post by pamirsawar » 08 Sep 2022, 06:05
Thanks for the reply. It's working perfectly now.
I added this "@extends('<package name>::base')" in the blade files in my package. Which was removed by me while copy pasting the files from the vendor folder which now I realized I should not have done that.
