"setLocale.after" event not working for my plugin
РоманАндрейчук
Post by РоманАндрейчук » 21 Sep 2022, 13:07
Aimeos 2021.x, php7.4
Hello. I'm create new plugin for basket. It changes the amount according to the client's logic.
class TenthFree
    extends \Aimeos\MShop\Plugin\Provider\Factory\Base
    implements \Aimeos\MShop\Plugin\Provider\Iface, \Aimeos\MShop\Plugin\Provider\Factory\Iface
	 public function register( \Aimeos\MW\Observer\Publisher\Iface $p ) : \Aimeos\MW\Observer\Listener\Iface
        $plugin = $this->getObject();
        $p->attach( $plugin, 'addProduct.after' );
        $p->attach( $plugin, 'deleteProduct.after' );
        $p->attach( $plugin, 'setProducts.after' );
        $p->attach( $plugin, 'addCoupon.after' );
        $p->attach( $plugin, 'deleteCoupon.after' );
        $p->attach( $plugin, 'setOrder.before' );
        $p->attach( $plugin, 'setLocale.before' );
        $p->attach( $plugin, 'setLocale.after' );
        return $this;
The plugin fires in all necessary events. But if I change the language or currency, the cart amount is not recalculated. Can you help me figure it out?
Re: "setLocale.after" event not working for my plugin
Post by aimeos » 22 Sep 2022, 15:23
If you change the language or currency, the basket is migrated in the basket frontend controller:
https://github.com/aimeos/ai-controller ... #L124-L162
In that case, setLocale() of the basket is never used because the basket object is created with a new locale object passed to its constructor directly:
https://github.com/aimeos/aimeos-core/b ... hp#L42-L49
Not sure if we can simply call Basket::setLocale() at the end of the migration:
https://github.com/aimeos/ai-controller ... #L154-L156
Can you test if that has negative consequences elsewhere?
РоманАндрейчук
Post by РоманАндрейчук » 24 Sep 2022, 16:24
Thank you! This method works. Can you add this code to your repository?
Found some more problems:
1)Sometimes a variable is not stored in the session. Because of this, there is an unnecessary initialization of the basket object.
https://github.com/aimeos/ai-controller ... e.php#L161
2) https://github.com/aimeos/ai-controller ... d.php#L514
This method does not check for the uniqueness of the added service. And many same delivery or payment services can be added to the basket object.
Post by aimeos » 27 Sep 2022, 07:33
РоманАндрейчук wrote: 24 Sep 2022, 16:24 Thank you! This method works. Can you add this code to your repository?
Thanks, the setLocale method is no called in dev-master and 2022.07.x-dev versions.
РоманАндрейчук wrote: 24 Sep 2022, 16:24 1)Sometimes a variable is not stored in the session. Because of this, there is an unnecessary initialization of the basket object.
Can you find out why the variable isn't stored?
РоманАндрейчук wrote: 24 Sep 2022, 16:24 2) https://github.com/aimeos/ai-controller ... d.php#L514
That's true. We've added checks in addService() and copyServices() now to avoid duplicate services. The new code is also available in dev-master and 2022.07.x-dev.
РоманАндрейчук
Post by РоманАндрейчук » 27 Sep 2022, 10:08
Is version 2021.x no longer supported?
Post by aimeos » 28 Sep 2022, 11:12
We are hesitating a bit porting back bigger changes to LTS versions.
But we've made the changes also available in aimeos/ai-controller-frontend:2021.10.x-dev now.
