Why the product attributes doesn't appear in the attribute template
ahmed31916
Post by ahmed31916 » 04 Oct 2022, 04:15
Hello Aimeos,
Why the product attributes doesn't appear in the "packages\theme1\templates\client\html\common\partials\attribute.php" template, although the product has lots of attributes?
Another question:
How to add more domains for the "packages\theme1\templates\client\html\common\partials\products.php" template?
Re: Why the product attributes doesn't appear in the attribute template
Post by aimeos » 05 Oct 2022, 11:19
ahmed31916 wrote: 04 Oct 2022, 04:15 Why the product attributes doesn't appear in the "packages\theme1\templates\client\html\common\partials\attribute.php" template, although the product has lots of attributes?
Depends on where you are. In the catalog list view, attributes are not loaded by default and only if you configure the domains or "basket-add" setting. In the catalog detail view, they are always available.
ahmed31916 wrote: 04 Oct 2022, 04:15 How to add more domains for the "packages\theme1\templates\client\html\common\partials\products.php" template?
For the catalog list view, you can use this setting:
https://aimeos.org/docs/2022.x/config/c ... s/#domains
There are more settings available ending with "domains" for different HTML client components.
