CMS pages return 404
snicto
Post by snicto » 12 Oct 2022, 14:22
"aimeos/aimeos-laravel": "~2022.07",
"laravel/framework": "^9.2",
Pages created in CMS are not returning appropriate pages via URL. So I have created a "/contacts" page in the CMS section, however, when entering <site>/contacts 404 is returned instead.
Adding the following to web.php routes does display the pages, however, when entering the wrong URL 404 is not displayed, but a blank page is displayed instead.
Route::match(['GET', 'POST'], '{path?}', '\Aimeos\Shop\Controller\PageController@indexAction')
    ->name('aimeos_page')->where( 'path', '.*' );
Re: CMS pages return 404
Post by aimeos » 12 Oct 2022, 14:56
snicto wrote: 12 Oct 2022, 14:22 Pages created in CMS are not returning appropriate pages via URL. So I have created a "/contacts" page in the CMS section, however, when entering <site>/contacts 404 is returned instead.
By default, the CMS pages are prefixed with "/p" to "/p/contacts" to avoid problems with Laravel auth routes.
snicto wrote: 12 Oct 2022, 14:22 Adding the following to web.php routes does display the pages, however, when entering the wrong URL 404 is not displayed, but a blank page is displayed instead.
The behavior has been improved in the recently released Aimeos 2022.10 LTS version.
snicto
Post by snicto » 12 Oct 2022, 16:19
Upgrading to 2022.10 resolved the issue, thx.
VirtualSpy
Post by VirtualSpy » 13 Oct 2022, 05:12
snicto wrote: 12 Oct 2022, 16:19 Upgrading to 2022.10 resolved the issue, thx.
snicto, may you check , does cms work for multishop in 2022.10 version
snicto
Post by snicto » 20 Oct 2022, 15:41
VirtualSpy wrote: 13 Oct 2022, 05:12
To extent.
If SHOP_MULTILOCALE=0
Everything works as expected.
if SHOP_MULTILOCALE=1
Pages under locales work, say "/en/p/contacts" works
However, default page "/en" is not being displayed, neither if set to a specific language or for all languages.
Post by aimeos » 20 Oct 2022, 15:50
In multi-site/multi-locale setups, CMS content that should be added to shop pages (home page is one of them) need the full URL path in URL field of the CMS page module, e.g. "/en" instead of "/"
snicto
Post by snicto » 20 Oct 2022, 16:21
aimeos wrote: 20 Oct 2022, 15:50 In multi-site/multi-locale setups, CMS content that should be added to shop pages (home page is one of them) need the full URL path in URL field of the CMS page module, e.g. "/en" instead of "/"
Yes that works, bit confusing tho.
