Admin panel and change default site code error
krzysiekp
Post by krzysiekp » 14 Oct 2022, 07:53
I changed default site code from "default" to "pl" and during logging to admin panel I receive error:
https://prnt.sc/AyKuQdolTNko
I have added in shop.php:
'mshop' => [
'locale' => [
'site' => 'pl', // used instead of "default"
VirtualSpy
Re: Admin panel and change default site code error
Post by VirtualSpy » 14 Oct 2022, 09:53
krzysiekp wrote: 14 Oct 2022, 07:53 I changed default site code from "default" to "pl" and during logging to admin panel I receive error:
'mshop' => [
'locale' => [
in your url there is showing site code "default" so it is showing error.
Post by aimeos » 15 Oct 2022, 13:50
Maybe your configuration in your config/shop.php isn't at the correct place so still "default" is used while you've already renamed the site in the database. You have to change exactly this line:
https://github.com/aimeos/aimeos-larave ... p.php#L178
Make also sure that your configuration isn't cached by Laravel and use:
php artisan optimize:clear
krzysiekp
Post by krzysiekp » 26 Oct 2022, 13:20
There is still the error
Post by aimeos » 27 Oct 2022, 14:55
Most likely, your admin user doesn't have "admin" or "editor" or "super" privileges or not valid site ID in his record in the users table ("1." for single site setups).
Relevant code:
https://github.com/aimeos/ai-admin-jqad ... hp#L46-L47
