Update stock using xml
AleksandarJovanovic
Post by AleksandarJovanovic » 26 Oct 2022, 18:09
Laravel framework version: 9.36.4
Aimeos Laravel version: * 2022.07.2
PHP Version: 8.1.9
Environment: Linux
Hello, can i update product stock using xml file.
Thanks and best regards
Re: Update stock using xml
Post by aimeos » 27 Oct 2022, 14:59
Only CSV files are possible for stock updates.
