How to get GrapesJS CMS trait values in the frontend?
kdim95
Post by kdim95 » 31 Oct 2022, 13:21
Laravel framework version: 9.37.0
Aimeos Laravel version: * 2022.07.2
PHP Version: 8.1.11
Environment: Linux
I've created a new trait for the cataloglist component.
The trait is
	type: 'select',
	label: 'Style',
	options: [
		{id: 'style-1', name: 'Style 1'},
		{id: 'style-2', name: 'Style 2'},
Changing the trait triggers a function onListStyleChange, which adds the style id to the cataloglist's classes.
My problem is that I can't figure out how to output the class in the frontend, specifically in:
vendor/aimeos/ai-cms-grapesjs/templates/client/html/cms/page/cataloglist
Re: How to get GrapesJS CMS trait values in the frontend?
Post by aimeos » 31 Oct 2022, 16:36
The values you add by JS in the CMS are read in this class:
https://github.com/aimeos/ai-cms-grapes ... #L107-L117
If you create a PR to add a style class, we will be happy to merge it into the core :-)
