custom controller
mahammadareef
custom controller
Post by mahammadareef » 02 Nov 2022, 09:33
i overwritten the pagecontroller for additional page load action, and when I updated the composer it gave me this warning ...
Warning: Ambiguous class resolution, "Aimeos\Shop\Controller\PageController" was found in both "D:\laragon\www\project1\vendor/aimeos-extensions/extcliqnshop/src\Aimeos\Shop\Controller\PageController.php" and "D:/laragon/www/project1/vendor/aimeos/aimeos-laravel/src\Aimeos\Shop\Controller\PageController.php", the first will be used.
things are working fine ..
is this right way...
Re: custom controller
Post by aimeos » 06 Nov 2022, 19:07
You can't create a class with the same name and namespace as an existing one. Instead, you have to create a new class and add appropriate routes in your ./routes/web.php file for your new controller class.
