User registration without {site}
snicto
Post by snicto » 03 Nov 2022, 18:10
I want users to be able to register, however, it seems it requires the site to be passed on all front-end URLs. Is it possible to set it up so the default site is used (multishop is not going to be used)? Since it will become a hassle in the long term to manage URLs with the site included.
Re: User registration without {site}
Post by aimeos » 06 Nov 2022, 19:11
If you use the Aimeos Laravel distribution and don't enable SHOP_MULTISHOP in your .env file, the {site} placeholder shouldn't be required in any URL. You should have a look into the ./routes/web.php file:
https://github.com/aimeos/aimeos/blob/m ... hp#L30-L45
snicto
Post by snicto » 07 Nov 2022, 17:28
aimeos wrote: 06 Nov 2022, 19:11 If you use the Aimeos Laravel distribution and don't enable SHOP_MULTISHOP in your .env file, the {site} placeholder shouldn't be required in any URL. You should have a look into the ./routes/web.php file:
My routes/web.php is like that and is unchanged from the core package. I am not using multishop, my .env is as follows:
SHOP_MULTILOCALE=1
SHOP_MULTISHOP=0
SHOP_REGISTRATION=1
When going to the front page, it returns the following error:
Missing required parameter for [Route: aimeos_home] [URI: {locale}/{site}] [Missing parameter: site].
What I have narrowed it down to is the shop.php config file:
https://github.com/aimeos/aimeos/blob/6 ... php#L6-L19
It triggers the requirement for {site}, removing the "config( 'app.shop_registration' )" does make everything work, however, registration cannot be completed and throws an error that it does not know what code/site the user is associated with.
Post by aimeos » 08 Nov 2022, 18:51
SHOP_REGISTRATION=1 is only for merchant registration in multi-site environments so if you activate this, multi-site is enabled too.
The Aimeos distribution has no user registration enabled because users can opt in to create an account automatically at the end of the checkout process.
snicto
Post by snicto » 10 Nov 2022, 14:23
Is there a way to enable user registration, so people can register before they make a purchase?
Post by aimeos » 11 Nov 2022, 06:11
You have to change the Laravel register controller in your installation accordingly:
https://github.com/aimeos/aimeos/blob/m ... roller.php
VirtualSpy
Post by VirtualSpy » 08 Dec 2022, 06:41
snicto wrote: 10 Nov 2022, 14:23 Is there a way to enable user registration, so people can register before they make a purchase?
just use this route
@if (Route::has('register'))
                        <a class="underline text-sm text-gray-600 hover:text-gray-900" href="{{ airoute('register') }}">
                            {{ __('Create Account') }}
                        </a>
                    @endif
on your login blade file
AhmadHelali
Post by AhmadHelali » 02 Mar 2023, 07:25
just use this route
                        </a>
                    @endif
I got error at registration :
Swift_TransportException
Expected response code 250 but got code "530", with message "530 5.7.1 Authentication required "
Post by aimeos » 03 Mar 2023, 12:06
You don't have the mail server configured in your .env file.
