How to stop conversion from cyrillic to latin in product URL segments?
kdim95
Post by kdim95 » 04 Nov 2022, 09:35
Laravel framework version: 9.38.0
Aimeos Laravel version: * 2022.07.2
PHP Version: 8.1.12
Environment: Linux
Aimeos automatically translates cyrillic to latin when saving the product URL segment, how do I prevent this from happening?
Re: How to stop conversion from cyrillic to latin in product URL segments?
Post by aimeos » 06 Nov 2022, 19:26
Because only latin characters are allowed in URLs, translation is always done automatically.
You can change that by adding a custom macro for the slug() method in the Aimeos string class:
https://github.com/aimeos/aimeos-base/b ... #L156-L165
\Aimeos\Base\Str::macro( 'slug', function( $str, string $lang = 'en', string $sep = '-' ) : string {
	return $str;
Add that code toy our AppServiceProvider class.
kdim95
Post by kdim95 » 07 Nov 2022, 09:33
Thanks, that works.
I added the code inside public function boot()
This is needed because I need to keep the original cyrillic URLs of an existing shop.
