Empty Fields in "mshop_media" table
Jieeezy
Post by Jieeezy » 06 Nov 2022, 21:42
Hi i tried to upload a obj file format in the admin panel but when i save it it output as "error saving data" but if i click it again it will output "item successfully saved" i cant seem to understand why in the fields in mshop_media are empty
link: < empty >
preview: {} // not necessary for thee.js
mimetype: <empty>
your response is much appreciated
Re: Empty Fields in "mshop_media" table
Post by aimeos » 06 Nov 2022, 22:08
Please have a look at the Log panel after the error occurs to see the details of the error and post them please.
Jieeezy
Post by Jieeezy » 06 Nov 2022, 22:18
i did inserted the mimetype in the $default but i still dont know why
  • File type "application/octet-stream" is not allowed
    #0 D:\laravelxr\vendor\aimeos\aimeos-core\src\Controller\Common\Media\Standard.php(51): Aimeos\Controller\Common\Media\Standard->getMimeType(Object(Aimeos\MW\Media\Application\Standard), 'files')
    #1 D:\laravelxr\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Product\Media\Standard.php(380): Aimeos\Controller\Common\Media\Standard->add(Object(Aimeos\MShop\Media\Item\Standard), Object(Nyholm\Psr7\UploadedFile))
    #2 D:\laravelxr\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Product\Media\Standard.php(149): Aimeos\Admin\JQAdm\Product\Media\Standard->fromArray(Object(Aimeos\MShop\Product\Item\Standard), Array)
    #3 D:\laravelxr\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Base.php(264): Aimeos\Admin\JQAdm\Product\Media\Standard->save()
    #4 D:\laravelxr\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Product\Standard.php(250): Aimeos\Admin\JQAdm\Base->save()
    #5 D:\laravelxr\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Common\Decorator\Base.php(151): Aimeos\Admin\JQAdm\Product\Standard->save()
    #6 D:\laravelxr\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Controller\JqadmController.php(214): Aimeos\Admin\JQAdm\Common\Decorator\Base->save()
    #7 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Controller.php(54): Aimeos\Shop\Controller\JqadmController->saveAction('default', 'product')
    #8 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction('saveAction', Array)
    #9 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Route.php(260): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Aimeos\Shop\Controller\JqadmController), 'saveAction')
    #10 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Route.php(205): Illuminate\Routing\Route->runController()
    #11 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Router.php(725): Illuminate\Routing\Route->run()
    #12 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\closure(Object(Illuminate\Http\Request))
    #13 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Middleware\SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #14 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
    #15 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Auth\Middleware\Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #16 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Auth\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure))
    #17 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #18 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
    #19 D:\laravelxr\vendor\laravel\framework\src\Illuminate\View\Middleware\ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #20 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
    #21 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Session\Middleware\StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #22 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Session\Middleware\StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest(Object(Illuminate\Http\Request), Object(Illuminate\Session\Store), Object(Closure))
    #23 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
    #24 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #25 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
    #26 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #27 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
    #28 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #29 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Router.php(726): Illuminate\Pipeline\Pipeline->then(Object(Closure))
    #30 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Router.php(703): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
    #31 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Router.php(667): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
    #32 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Routing\Router.php(656): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
    #33 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(190): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
    #34 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\closure(Object(Illuminate\Http\Request))
    #35 D:\laravelxr\app\Http\Middleware\SetLocale.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #36 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): App\Http\Middleware\SetLocale->handle(Object(Illuminate\Http\Request), Object(Closure))
    #37 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #38 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
    #39 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
    #40 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #41 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
    #42 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
    #43 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #44 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
    #45 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #46 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
    #47 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Http\Middleware\HandleCors.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #48 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Http\Middleware\HandleCors->handle(Object(Illuminate\Http\Request), Object(Closure))
    #49 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Http\Middleware\TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #50 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
    #51 D:\laravelxr\app\Http\Middleware\TrustHosts.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #52 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): App\Http\Middleware\TrustHosts->handle(Object(Illuminate\Http\Request), Object(Closure))
    #53 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
    #54 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(165): Illuminate\Pipeline\Pipeline->then(Object(Closure))
    #55 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(134): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
    #56 D:\laravelxr\public\index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
    #57 D:\laravelxr\vendor\laravel\framework\src\Illuminate\Foundation\resources\server.php(16): require_once('D:\\laravelxr\\pu...')
    #58 main
Post by aimeos » 06 Nov 2022, 22:37
You need to add "application/octet-stream" as allowed mimetype in your configuration:
controller/common/media/files/allowedtypes
See also: https://github.com/aimeos/aimeos-core/b ... #L574-L605
Jieeezy
Post by Jieeezy » 07 Nov 2022, 08:46
It's already working thank you so much, i just added
'application/octet-stream' => 'glb', and
'application/octet-stream' => 'gltf',
in vendor > aimeos > aimeos-core > config > controller.php
Post by aimeos » 08 Nov 2022, 18:38
Only the last one will be used because the keys are the same.
