Aimeos 2021.07 database transaction
krzysiekp
Post by krzysiekp » 16 Nov 2022, 17:34
How to do database transaction in Aimeos 2021.07 ? I have a code:
 $orderCntl = \Aimeos\Controller\Frontend::create($this->context, 'order' );
            $basketCntl = \Aimeos\Controller\Frontend::create($this->context, 'basket' );
            $this->setAddress($req);
            $basket = $basketCntl->store();
            //begin transaction
            $orderItem = $orderCntl->add($basket->getId(), ['order.type' => 'web'])->store();
            //commit transaction
            //rollback
Database manager have below methods:
array:6 [▼
  0 => "__construct"
  1 => "__destruct"
  2 => "__clone"
  3 => "__sleep"
  4 => "acquire"
  5 => "release"
Re: Aimeos 2021.07 database transaction
Post by aimeos » 17 Nov 2022, 17:32
Please update to 2021.10 LTS as 2021.07 and before isn't supported any more.
The controllers don't have methods for begin/commit/rollback transactions because they use them internally if required, only the managers have, e.g.:
$manager = \Aimeos\MShop::create( $context, 'order' );
$manager->begin();
try {
	$manager->commit();
} catch( \Exception $e ) {
	$manager->rollback();
krzysiekp
Post by krzysiekp » 18 Nov 2022, 07:57
What exact steps do I need to follow outside of composer to upgrade from 2021.07 to 2021.10?
How big are the differences between 2021.07 and 2021.10 ?
krzysiekp
Post by krzysiekp » 18 Nov 2022, 13:46
After composer update to 2021.10 version when I execute below command:
php artisan aimeos:setup
I receive error:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'statuspayment' in 'where clause': UPDATE "mshop_order_base_product" SET "statuspayment" = -1 WHERE "statuspayment" IS NULL
Post by aimeos » 19 Nov 2022, 08:02
Seems to be a dependency issue. Can you please execute this command and try again:
composer req aimeos/aimeos-core:2021.10.x-dev
krzysiekp
Post by krzysiekp » 21 Nov 2022, 08:03
It's working but now I use:
 "aimeos/aimeos-laravel": "2021.10.6"
and
"aimeos/aimeos-core": "2021.10.x-dev"
Maybe I should update aimeos/aimeos-laravel to version 2021.10.x-dev as well ?
Post by aimeos » 21 Nov 2022, 15:21
No, the .x-dev versions only contain non-tagged commits that will be available for all users as soon as a new version gets tagged. It's only for testing bugfixes.
krzysiekp
Post by krzysiekp » 21 Nov 2022, 20:13
So when will the release of the new version 2021.10 with these fixes be?
Post by aimeos » 22 Nov 2022, 14:38
New minor releases should be available tomorrow.
