Content in ai-cms-grapesjs module is not saving
kdim95
Post by kdim95 » 07 Dec 2022, 15:14
Laravel framework version: 9.43.0
PHP Version: 8.1.13
Environment: Linux
After updating Aimeos, the content in the CMS module in the backend is not saving.
There is no error log, after saving, it only says "saved successfully" and no error log.
How should I debug this?
snicto
Re: Content in ai-cms-grapesjs module is not saving
Post by snicto » 07 Dec 2022, 19:08
If you edit Basic information as well as Subpanels, it should save all the data properly. It is not saved only if Basic info is unchanged.
Post by aimeos » 08 Dec 2022, 08:12
We had a problem in the Aimeos core which prevented saving of dependent items.
Please make sure, you have at least aimeos/aimeos-core:2022.10.6 and aimeos/ai-cms-grapesjs:2022.10.5
kdim95
Post by kdim95 » 08 Dec 2022, 09:36
Thank you guys, I executed composer update and it was fixed:
Upgraded aimeos/ai-cms-grapesjs 2022.10.4 => 2022.10.5
