Show FlatPickr calender for date input
kartikbhat
Post by kartikbhat » 14 Dec 2022, 06:30
how can I make flatpickr show expected datepicker for input for of type date.
at Admin panel,
v-bind:config="Aimeos.flatpickr.datetime"
is not showing default datepicker itself..
Help to to show flatpickr specific date picker..
TIA :)
Re: Show FlatPickr calender for date input
Post by aimeos » 15 Dec 2022, 07:42
To show the VueJS date picker component, make sure you have a parent node <div class="vue"> in the template. This will create a VueJS application for that block like here:
https://github.com/aimeos/ai-admin-jqad ... m.php#L287
Then, the input field for the date picker must look like this one:
https://github.com/aimeos/ai-admin-jqad ... #L432-L437
