configuration
VirtualSpy
configuration
Post by VirtualSpy » 15 Dec 2022, 07:04
laravel version 9.36.4 , Aimeos version 2022.10.3 and PHP version 8.1.3 (Win)
some config has not used in src for template body, so if i overwrite that templates with same name from my extension or theme it works but i want to know if any aimeos update will come then that template will affect by aimeos update or not.
for example this config https://aimeos.org/docs/latest/config/ ... te-body_4 has not used in its src.
Re: configuration
Post by aimeos » 16 Dec 2022, 08:49
As long as you place all your customized templates in your own Aimeos extension, they won't be affected by updates.
