Get product details with basket
Is it possible to get additional product information (product,attribute,media) from get request to jsonapi/basket and from post request for adding product to basket? I tried to use "include=product" param but with no luck. I inspected templates/client/jsonapi/basket/standard.php file and found next block:
getProductItem method returns null in my scenarios.
Laravel 9.43
"aimeos/aimeos-laravel": "2022.10.4",
"aimeos/ai-client-jsonapi": "2022.10.2",
"aimeos/aimeos-core": "2022.10.7"
if( $product = $orderProduct->getProductItem() )
$entry['relationships']['product']['data'][] = ['type' => 'product', 'id' => $product->getId()];
$result = array_merge( $result, $this->jincluded( $product, $fields ) );
Laravel 9.43
Re: Get product details with basket
Unfortunately, the basket endpoint manages a serialized representation of the (future) order and doesn't store any related items (and doesn't fetch them too). Only if the basket is stored and becomes an order, you are able to retrieve the original product of each order product item along with other related items to the product.
