Multi site redirect based on location
VirtualSpy
Post by VirtualSpy » 27 Dec 2022, 00:58
laravel version 9.36.4 , Aimeos version 2022.10.3 and PHP version 8.1.3 (Win)
Multi site automatically redirect on default site so i want redirect multi site based on location please tell me is it possible and what will it's process.
Re: Multi site redirect based on location
Post by aimeos » 28 Dec 2022, 21:03
What is "location" in terms of what you know from the user? IP? Zip code?
VirtualSpy
Post by VirtualSpy » 28 Dec 2022, 23:24
aimeos wrote: 28 Dec 2022, 21:03 What is "location" in terms of what you know from the user? IP? Zip code?
Location is based on IP address
Post by aimeos » 30 Dec 2022, 19:10
You should implement a redirect for the home page ("/") using a GeoIP database.
VirtualSpy
Post by VirtualSpy » 03 Jan 2023, 04:55
aimeos wrote: 30 Dec 2022, 19:10 You should implement a redirect for the home page ("/") using a GeoIP database.
i tried like this
$ip = \Request::ip();
$currentUserInfo = Location::get($ip);
if($currentUserInfo!==false) {
$country=$currentUserInfo->countryName;
if (config('app.shop_multishop')) {
    if(isset($country)) {
    if($country!=="India") {
    $conf['prefix'] .= '/uae';
   else {
    $conf['prefix'] .= '/{site}';
    $conf['where']['site'] = '[A-Za-z0-9\.\-]+';
if ($conf['prefix']) {
    Route::get('/', function () use ($params) {
        return redirect(airoute('aimeos_home', $params));
i am getting $conf['prefix'] = /uae
but it is not redirecting on uae site because it is redirecting from shop.php
 'mshop' => [
        'locale' => [
            'site' => 'in', // used instead of "default"
please tell me where this config is using or tell me other solution
VirtualSpy
Post by VirtualSpy » 04 Jan 2023, 14:14
VirtualSpy wrote: 03 Jan 2023, 04:55
i tried like this
   else {
 'mshop' => [
        'locale' => [
i got this config
 'mshop' => [
        'locale' => [
is using in airoute function of aimeos-laravel but can i overwrite or extend this function please tell me
VirtualSpy
Post by VirtualSpy » 04 Jan 2023, 14:46
VirtualSpy wrote: 04 Jan 2023, 14:14
i tried like this
   else {
 'mshop' => [
        'locale' => [
i got this config
 'mshop' => [
        'locale' => [
ok now i understand i should use redirect()->intended in place of airoute function.
Post by aimeos » 06 Jan 2023, 12:14
Your route code also doesn't work because "/{site}" must be always the path prefix and "uae" is only a value for that placeholder. The correct code should look something like this:
	if(($currentUserInfo = Location::get(\Request::ip())) !== false
		&& $currentUserInfo->countryName !== 'India') {
		$param['site'] = 'uae';
