Standalone vs Package
Wall0fDeath
Post by Wall0fDeath » 28 Dec 2022, 10:19
Hi!
Debian GNU/Linux 11 (bullseye) + vbox
Standalone:
php - 8.2
aimeos-core - 2022.10.7
ai-laravel - 2022.10.4
laravel/framework - 9.37.0
Package:
php - 8.2
I have a Standalone install, what uses webpack-mix, and when I install Aimeos as a Laravel package, it will use vite. My boss decided we should use the standalone version. Is there any way to install the standalone shop with vite (instead of webpack) with a configuration change or something? (I can take the hard way, if there is no other option :D)
Re: Standalone vs Package
Post by aimeos » 28 Dec 2022, 21:08
Aimeos is independent of both, Webpack and Vite. They are used/provided by the Laravel application and the Aimeos standalone application uses the laravel/laravel package as base (https://github.com/laravel/laravel). Laravel moved from Webpack to Vite in Laravel 9 and you can copy the files from Laravel 9 repo to use Vite instead.
Wall0fDeath
Post by Wall0fDeath » 30 Dec 2022, 13:08
Yep, that's the "hard way" ( if i can call the change of 4 files to that :D )
Thank you! Have a nice day! :))
