Laravel user schema update
I'm trying to modify the user schema and change the existing column
but when I run the command "php artisan aimeos:setup" I get the message:
Has anyone had the same issue or can suggest what's wrong?
Here is my file
Similar works for other tables but not for "users"
I have aimeos/aimeos-laravel 2021.10.6
Using schema from customer.php
There is no table with name 'users' in the schemaHere is my file
return [
'table' => [
'users' => function (\Doctrine\DBAL\Schema\Schema $schema) {
$table = $schema->getTable('users');
$table->changeColumn('name', ['length' => 255, 'default' => '']);
return $schema;
];I have aimeos/aimeos-laravel 2021.10.6
Re: Laravel user schema update
Guess, the users table is available, isn't it?
Do you have different databases for all users* tables and the rest?
users table is present and the changes work from aimeos/ai-laravel, but when I created the same customer.php file in my extension and want to change some columns, when I run the setup command, I get this result
Add "ai-laravel" into the "depends" section of the manifest.php in your own extension to get the dependencies right.
thanks a lot, it seems the list of dependencies was generated automatically and I completely forgot about it
