Catalog Manager - Get child catalog items ?
kdim95
Post by kdim95 » 13 Jan 2023, 10:16
Laravel framework version: 9.47.0
PHP Version: 8.2.1
Environment: Linux
What's the best way to get the child catalog items in Catalog Manager search results?
My code:
$catalog_manager = \Aimeos\MShop::create( $this->context, 'catalog' );
$catalog_items = $catalog_manager->search( $catalog_filter ); // Catalog children missing here
I want to be able to use getChildren() on each item inside $catalog_items, but the result is always empty.
kdim95
Re: Catalog Manager - Get child catalog items ?
Post by kdim95 » 13 Jan 2023, 11:09
I came up with this, since the items have a catalog.parentid.
The function gets the catalog items which have a matching catalog.parentid.
$catalog_item_children = getCatalogChildren( $catalog_items, $catalog_items->first() );
function getCatalogChildren( $catalog_items, $catalog_item )
	return $catalog_items->filter( function($value, $key) use($catalog_item) {
		return $value->getParentId() == $catalog_item->getId();
Post by aimeos » 13 Jan 2023, 14:59
The getTree() method is the only one that fetches the children and returns a tree structure:
https://github.com/aimeos/aimeos-core/b ... hp#L33-L43
Use the frontend controller if you need to fetch categories for the frontend:
https://github.com/aimeos/ai-controller ... hp#L73-L80
