How can i to add the Last-Modified header for some actions in CatalogController.php?
РоманАндрейчук
Post by РоманАндрейчук » 18 Jan 2023, 12:45
Hello. I am use next configuration: PHP7.4, Aimeos 2021.10, Laravel.
Can you advise me. How to add this header? So far I can see that I will need to override the entire controller and override routes for the actions I need. Can this be done easier?
Re: How can i to add the Last-Modified header for some actions in CatalogController.php?
Post by aimeos » 19 Jan 2023, 16:37
Unfortunately, it's not possible easily in Laravel and you have to create your own controller and adapt the routes.
Another option might be to use a middleware similar to this one which adds the header:
https://github.com/abordage/laravel-last-modified
РоманАндрейчук
Post by РоманАндрейчук » 25 Jan 2023, 13:20
Thank you. I have seen this module. It is used in laravel controller. To use it, I have to override the entire CatalogController.
