Auth pages using Aimeos views
snicto
Post by snicto » 25 Jan 2023, 19:55
All authorization pages use their own views and etc. How could I add existing Aimeos theme views to the login forms? Basically, I want to achieve that authorization pages look the same as shop pages, so the user feels like he is still on the same page, not directed to some backend page.
Re: Auth pages using Aimeos views
Post by aimeos » 27 Jan 2023, 09:30
You need to use the Aimeos base Blade template for all auth pages. and their templates are in the ./resources/views/auth/ folder. Extend from the base Blade template and use the @content section for the auth components, e.g.:
@extends( ( app( 'aimeos.context' )->get()->locale()->getSiteItem()->getTheme() ?: 'shop' ) . '::base')
@section('content')
	// HTML code for the Laravel auth component
@endsection
