[SOLVED]How to add meta tags to the HTML page for Catalog list and Catalog detail page
kartikbhat
Post by kartikbhat » 30 Jan 2023, 10:30
I am adding meta keywords and meta description from admin panel under texts section
Now how can I bring these added texts as a value for meta tags..
How Can I add product description as a meta description ?
TIA :)
Re: How to add meta tags to the HTML page for Catalog list and Catalog detail page
Post by aimeos » 31 Jan 2023, 11:10
The meta tags in the product detail page are added here:
https://github.com/aimeos/ai-client-htm ... hp#L35-L72
kartikbhat
Post by kartikbhat » 31 Jan 2023, 11:27
How can I refer this header.php in my blade file ? in which section I mean
under $aiheader it will be available ?
kartikbhat
Post by kartikbhat » 31 Jan 2023, 12:27
I have added
<?= $aiheader['catalog/detail'] ?? '' ?>
in a related blade file and it works...
Thank you
