Change catalog actions status if actived
PedroLópezAndradas
Post by PedroLópezAndradas » 01 Feb 2023, 11:53
Hello!
Is there any option to change the style of the catalog action icons when they are activated?
For example, if a product is a favorite, the heart icon should be filled in.
Now there is no "active" class or something similar, but maybe it's a configuration setting I missed.
If this functionallity does not exist, what dou you think would be the best approach to achieve this?
Thanks!
Re: Change catalog actions status if actived
Post by aimeos » 02 Feb 2023, 13:49
The best way would be to use the JSON REST API to fetch the favorite products of the logged in customer:
https://aimeos.org/docs/latest/frontend ... -relations
We would love to get the feature into the Aimeos core. If you can create a PR, we will merge it for sure! :-)
