Migration/setup task
VirtualSpy
Post by VirtualSpy » 03 Feb 2023, 14:37
laravel version 9.48.0 , Aimeos version 2022.10.4 and PHP version 8.1.3 (Win)
does Aimeos migration have column modifiers like laravel migration https://laravel.com/docs/9.x/migrations ... -modifiers ,because i want to Place the column "after" another column please tell me if it is possible or can i use laravel migration for modify any core table of aimeos , if it will not affect to manager and item class.
Re: Migration/setup task
Post by aimeos » 05 Feb 2023, 16:26
The used Upscheme library supports modifiers but no after() because only MySQL is offering that and column order isn't important.
The list of available column modifiers offered by Upscheme:
https://upscheme.org/#column-modifiers
