product search
VirtualSpy
product search
Post by VirtualSpy » 07 Feb 2023, 07:42
laravel version 9.48.0 , Aimeos version 2022.10.4 and PHP version 8.1.3 (Win)
product search is using =~ (string starts with) and ~= (string contains, slow!) so I want to change the operator but I could not understand from where it will change please help me change the operator of the product search.
Thanks in Advance
VirtualSpy
Re: product search
Post by VirtualSpy » 07 Feb 2023, 13:00
VirtualSpy wrote: 07 Feb 2023, 07:42 laravel version 9.48.0 , Aimeos version 2022.10.4 and PHP version 8.1.3 (Win)
Thanks in Advance
i have changed operator from ai-catsuggest package for product search suggestion.
Re: product search
Post by aimeos » 09 Feb 2023, 08:01
Product search for the frontend is done by the index manager using fulltext search, which doesn't use "=~" or "~=":
https://github.com/aimeos/aimeos-core/b ... rd.php#L61
