Translate functionality
kartikbhat
Post by kartikbhat » 16 Feb 2023, 15:51
What is the difference between
$this->translate( 'admin', 'Basic' )
and
aitrans( 'Top', $params = [], $domain = 'client', $locale = null )
When to use which method?
TIA :)
Re: Translate functionality
Post by aimeos » 19 Feb 2023, 10:27
"aitrans()" is a helper method you can use in Blade templates to access Aimeos translations, "$this->translate()" is a view helper only available in Aimeos views.
kartikbhat
Post by kartikbhat » 20 Feb 2023, 06:15
What to pass for the parameters of the aitrans() function
$params...
$domain...
$locale...
can I get a information on what these parameters indicate and how to pass language key in this function call ?
TIA :)
Post by aimeos » 21 Feb 2023, 08:30
The documentation for aitrans() is available here:
https://aimeos.org/docs/latest/laravel/ ... anslations
The parameters are:
- $singular : Text to translate
- $params : Array of values if $singular contains sprintf() placeholders (e.g. %1$s)
- $domain : Translation domain (same as first parameter for $this->translate())
- $locale : Language code if different from the one for the page
For your example:
aitrans('Top')
With placeholders:
aitrans('%1$s results found', [10])
With different domain:
aitrans('price:default', [], 'client/ext')
Output French translation in e.g. a page with English texts:
aitrans('Top', [], 'client', 'fr)
kartikbhat
Post by kartikbhat » 21 Feb 2023, 08:42
Thank you for the detailed explaination
I didn't got the value 'client' - a third parameter
is it a index present in shop.php ?
'client' => [
  'en'=>[
      'header'=>[
          'key1'=>'value2',
          'key2'=>'value2',
      'footer'=>[
            'key3'=>'value3',
            'key4'=>'value4',
   'fr'=>[
      'header'=>[
          'key1'=>'value2',
          'key2'=>'value2',
      'footer'=>[
            'key3'=>'value3',
            'key4'=>'value4',
   'de'=>[
      'header'=>[
          'key1'=>'value2',
          'key2'=>'value2',
      'footer'=>[
            'key3'=>'value3',
            'key4'=>'value4',
how these values can be access from aitrans() function
Please let me know...
TIA :)
Post by aimeos » 22 Feb 2023, 15:39
Yes, the third parameter matches e.g. the
'i18n' => ['client' => []]
// or
'i18n' => ['client/ext' => []]
key in your ./config/shop.php
kartikbhat
Post by kartikbhat » 25 Apr 2023, 11:09
How to maintain separate files for multiple language keys, as I have huge set of translative sentences/words, as we do in Laravel, separate folder for each languages.
Is it possible in Aimeos ? how we can access from either $translate or aitrans() functions ?
Post by aimeos » 29 Apr 2023, 07:18
For a large list of translations, use the Gettext files instead where you have one file per language in an optimized binary format:
https://aimeos.org/docs/latest/developer/translations/
