Istall Aimeos with Laravel 10 Problem
WouterLeybaert
Post by WouterLeybaert » 12 Mar 2023, 14:59
Error;
Problem 1
- aimeos/aimeos-laravel 2022.10.6 requires aimeos/aimeos-core 2022.10.* -> satisfiable by aimeos/aimeos-core[2022.10.1, ..., 2022.10.12].
- aimeos/aimeos-laravel[2022.10.1, ..., 2022.10.5] require laravel/framework ^9.0 -> found laravel/framework[v9.0.0, ..., v9.52.4] but it conflicts with your root composer.json require (^10.0).
- aimeos/aimeos-core[2022.10.1, ..., 2022.10.12] require ext-intl * -> it is missing from your system. Install or enable PHP's intl extension.
- Root composer.json requires aimeos/aimeos-laravel ~2022.10 -> satisfiable by aimeos/aimeos-laravel[2022.10.1, ..., 2022.10.6].
my versions;
- PHP 8.2.3
- composer 2.5.1
- Laravel 10.3.3
Any solutions that don't resort me to downgrade a version of Laravel?
Re: Istall Aimeos with Laravel 10 Problem
Post by aimeos » 12 Mar 2023, 15:06
Laravel 10 is only supported by the dev-master version at the moment and will be officially supported in four weeks with the 2023.04 release.
