Translation with $this->context()->i18n()->dt() not working
kdim95
Post by kdim95 » 14 Mar 2023, 14:04
PHP Version: 8.2.3
Environment: Linux
I've created a new decorator in the namespace Aimeos\MShop\Order\Manager\Base\Service\Decorator.
I'm attempting to translate this country code inside the search() method:
dump( $this->context()->i18n()->dt( 'client', 'AZ') )
The translation does not work, it returns AZ, when it should return Azerbaijan.
Re: Translation with $this->context()->i18n()->dt() not working
Post by aimeos » 14 Mar 2023, 16:35
You are using the wrong translation domain and it should be instead:
$this->context()->translate( 'country', 'AZ' );
kdim95
Post by kdim95 » 15 Mar 2023, 13:34
Thank you, I did have the wrong domain. It works now.
