Adding a Subpart
swpierce
Adding a Subpart
Post by swpierce » 15 Nov 2015, 03:36
I'm wanting to display subcategories as part of the catalog list. Reading through another post, it seems like the best way to do it is to add a subpart, so this is what I did:
In my Laravel project, I created a directory structure as such:
<root>/ext/subcategories/client/html/src/Client/Html/Catalog/List/Subcategories
<root>/ext/subcategories/client/html/layouts/catalog/list
In the first directory, I put Default.php with all the skeleton code and the following class declaration and _setViewParams (as per the other post I read):
class Client_Html_Catalog_List_Subcategories_Default
    extends Client_Html_Abstract
    implements Client_Html_Common_Client_Factory_Interface
protected function _setViewParams( MW_View_Interface $view, array &$tags = array(), &$expire = null ) {
        if ( !isset( $this->_cache ) ) {
            $this->addMetaItem( $itemOrItemList, 'catalog', $this->_expire, $this->_tags );
            $this->_addMetaList( $prodid, 'catalog', $this->_expire );
            $controller = Controller_Frontend_Factory::createController( $this->_getContext(), 'catalog' );
            $view->subcategoriesList = $controller->getCatalogTree( $view->param( 'f_catid' ), array( 'text', 'media' ), MW_Tree_Manager_Abstract::LEVEL_LIST );
            $this->_cache = $view;
        $expire = $this->_expires( $this->_expire, $expire );
        $tags = array_merge( $tags, $this->_tags );
        return $this->_cache;
In the layouts directory tree, I put subcategories-header-default.html and subcategories-body-default.html
In the shop.php file, I put this configuration:
'catalog' => array(
     'list' => array(
          'subparts' => [''head', 'quote', 'promo', 'subcategories', 'pagination', 'items', 'pagination' ],
Cleared the cache and reloaded the page but I don't see anything. I'm guessing it's not working due to my inexperience with Laravel but I'm not sure what I'm doing wrong...
Re: Adding a Subpart
Post by aimeos » 15 Nov 2015, 10:52
What do you expect as output? At the moment, you assign a catalog item with it's direct children to your view and they contain category texts and pictures (if there are any). You should leave out the "meta" things at the moment to make it easier as the code is currently invalid.
swpierce wrote: In the layouts directory tree, I put subcategories-header-default.html and subcategories-body-default.html
The easiest way to see what's in your view is to do a
print_r( $this->subcategoriesList );
swpierce wrote: Cleared the cache and reloaded the page but I don't see anything. I'm guessing it's not working due to my inexperience with Laravel but I'm not sure what I'm doing wrong...
If you didn't disable the cache during development (https://github.com/aimeos/aimeos-laravel#hints), you have to run
php artisan aimeos:cache
after each change.
swpierce
Post by swpierce » 15 Nov 2015, 14:02
Right. In the subcategories-body-default.html file, I basically do the print_r statement like you suggested. I never see it. I have also tried just putting some static HTML in the view instead - that never gets displayed either. Fairly sure the subpart isn't getting called. Thought it might be because I put it in the wrong directory or configured it wrong.
EDIT: I also tried copying my code into the aimeos-core directory tree (even though I know it shouldn't go there) but it still doesn't work.
Here is the full code of the Default.php:
<?php
    private $_subPartPath = 'client/html/catalog/list/sbcategories/default/subparts';
    private $_subPartNames = array();
    private $_cache;
    public function getBody( $uid = '', array &$tags = array(), &$expire = null ) {
        $view = $this->_setViewParams($this->getView(), $tags, $expire );
        $html = '';
        foreach( $this->_getSubClients() as $subclient ) {
            $html .= $subclient->setView( $view )->getBody( $uid, $tags, $expire );
        $view->subcategoriesBody = $html;
        $tplconf = 'client/html/catalog/list/subcategories/default/template-body';
        $default = 'catalog/list/subcategories-body-default.html';
        return $view->render( $this->_getTemplate( $tplconf, $default ) );
    public function getHeader( $uid = '', array &$tags = array(), &$expire = null ) {
        $view = $this->_setViewParams( $this->getView(), $tags, $expire );
        $html = '';
            $html .= $subclient->setView( $view )->getHeader( $uid, $tags, $expire );
        $view->subcategoriesHeader = $html;
        $tplconf = 'client/html/catalog/list/subcategories/default/template-header';
        $default = 'catalog/list/subcategories-header-default.html';
    public function getSubClient( $type, $name = null ) {
        return $this->_createSubClient( 'catalog/list/subcategories/' . $type, $name );
    public function _getSubClientNames() {
        return $this->_getContext()->getConfig()->get( $this->_subPartPath, $this->_subPartNames );
        return $view;
Post by aimeos » 15 Nov 2015, 14:06
swpierce wrote:Right. In the subcategories-body-default.html file, I basically do the print_r statement like you suggested. I never see it. I have also tried just putting some static HTML in the view instead - that never gets displayed either. Fairly sure the subpart isn't getting called. Thought it might be because I put it in the wrong directory or configured it wrong.
How does your getBody() method look like? There's the location of the template specified. For a working example this may help:
https://aimeos.org/docs/Developers/Html ... Body.28.29
swpierce
Post by swpierce » 15 Nov 2015, 15:01
Here is my getBody() method:
        $html = '';
I put the full code of the Default.php file in my previous post.
I do not believe my subpart is getting used at all. I intentionally added some bad code to Default.php but nothing happens - site works when it should break if it is calling my subpart. I have content cache disabled and I ran aimeos:cache anyway just in case.
Post by aimeos » 15 Nov 2015, 15:12
swpierce wrote: In the shop.php file, I put this configuration:
'catalog' => array(
     'list' => array(
If it's not found, most likely this is at the wrong place ("default" is missing in your case). It must be in
return array(
  'client' => array(
    'html' => array(
      'catalog' => array(
        'list' =>array(
          'default' => array(
Here's the documentation for the config setting: https://aimeos.org/docs/Configuration/C ... t/subparts
swpierce
Post by swpierce » 15 Nov 2015, 15:23
I knew it was something simple I was overlooking! Thanks!
One last question on this topic:
If I put the code in the ext directory tree, I get:
Class "Client_Html_Catalog_List_Subcategories_Default" not available
If I put the code in the aimeos-core directory tree, it works.
Shouldn't I avoid putting it in the aimeos-core tree to prevent issues during upgrades? If so, where should I put the code if the ext directory tree is the wrong place. OR, if the ext directory is the right place, is there something I should do to get the code to load from there?
Thanks again for all the help!
Post by aimeos » 15 Nov 2015, 15:36
I'm almost sure this is an autoloader issue. Maybe it helps to run
composer dump-autoload
in your application directory.
If not, you may try to add the "client/html/src" directory to the "autoload"/"classmap" section of your composer.json file.
swpierce
Post by swpierce » 15 Nov 2015, 16:37
Adding 'ext' to the autoload classmap worked in getting the class to load. but if I leave stuff in the ext directory tree, it is unable to find the templates:
Template "catalog/list/subcategories-body-default.html" not available
Post by aimeos » 15 Nov 2015, 16:52
The template directory is configured in the manifest.php file of your extension and it should contain these lines by default:
'custom' => array(
	'client/html' => array(
		'client/html/layouts',
Your template must then be in .../ext/client/html/layouts/catalog/list/subcategories-body-default.html
