problem in making manager for mydomain
Zainali95
Post by Zainali95 » 25 Mar 2023, 19:17
Class "\Aimeos\MShop\Mydomain\Manager\Standard" not found
#0 D:\personal\myshop\vendor\aimeos\aimeos-core\src\MShop.php(274): Aimeos\MShop::createManager(Object(Aimeos\MShop\Context), '\\Aimeos\\MShop\\M...', '\\Aimeos\\MShop\\M...', 'mydomain')
#1 D:\personal\myshop\vendor\aimeos\aimeos-core\src\MShop.php(84): Aimeos\MShop::instantiate(Object(Aimeos\MShop\Context), Array, 'mydomain', 'Standard')
#2 D:\personal\myshop\packages\hello-world\src\Admin\JQAdm\Mypanel\Standard.php(190): Aimeos\MShop::create(Object(Aimeos\MShop\Context), 'mydomain')
#3 D:\personal\myshop\vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Common\Decorator\Base.php(162): Aimeos\Admin\JQAdm\Mypanel\Standard->search()
#4 D:\personal\myshop\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Controller\JqadmController.php(235): Aimeos\Admin\JQAdm\Common\Decorator\Base->search()
#5 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Controller.php(54): Aimeos\Shop\Controller\JqadmController->searchAction('default', 'mypanel')
#6 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction('searchAction', Array)
#7 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Route.php(260): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Aimeos\Shop\Controller\JqadmController), 'searchAction')
#8 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Route.php(205): Illuminate\Routing\Route->runController()
#9 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Router.php(798): Illuminate\Routing\Route->run()
#10 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\closure(Object(Illuminate\Http\Request))
#11 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Middleware\SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#12 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#13 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Auth\Middleware\Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#14 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Auth\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure))
#15 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#16 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#17 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\View\Middleware\ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#18 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#19 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Session\Middleware\StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#20 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Session\Middleware\StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest(Object(Illuminate\Http\Request), Object(Illuminate\Session\Store), Object(Closure))
#21 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#23 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#24 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#25 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#26 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#27 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Router.php(799): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#28 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Router.php(776): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#29 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Router.php(740): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#30 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Routing\Router.php(729): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#31 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(190): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#32 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\closure(Object(Illuminate\Http\Request))
#33 D:\personal\myshop\app\Http\Middleware\SetLocale.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#34 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): App\Http\Middleware\SetLocale->handle(Object(Illuminate\Http\Request), Object(Closure))
#35 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#36 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#39 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#41 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#42 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#44 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#45 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Http\Middleware\HandleCors.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#46 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Http\Middleware\HandleCors->handle(Object(Illuminate\Http\Request), Object(Closure))
#47 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Http\Middleware\TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#48 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#49 D:\personal\myshop\app\Http\Middleware\TrustHosts.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#50 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(180): App\Http\Middleware\TrustHosts->handle(Object(Illuminate\Http\Request), Object(Closure))
#51 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#52 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(165): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#53 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(134): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#54 D:\personal\myshop\public\index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#55 D:\personal\myshop\vendor\laravel\framework\src\Illuminate\Foundation\resources\server.php(16): require_once('D:\\personal\\mys...')
#56 main
Re: problem in making manager for mydomain
Post by aimeos » 27 Mar 2023, 17:13
You've requested a manager for a domain which doesn't exist, e.g. your code look like:
$manager = \Aimeos\MShop::create( $this->context(), 'mydomain' );
But you haven't implemented the \Aimeos\MShop\Mydomain\Manager\Standard class.
