Currency conversion
kdim95
Currency conversion
Post by kdim95 » 30 Mar 2023, 13:54
PHP Version: 8.2.4
Environment: Linux
I'm looking to convert the currency to EUR with a fixed conversion rate for the PayPalExpress payment provider.
The problem is that the store will work only with one specific currency, but I want to change the currency when making the order. That is because PayPal does not work with the currency that the store will support, so I need to convert it to euro.
How should I make this change?
So far I've created a decorator for the payment service and added it to the provider, not sure if this is the correct approach.
My plan is to update the order with the new currency id and recalculate the value here.
namespace Aimeos\MShop\Service\Provider\Decorator;
class CurrencyToEuro
	extends \Aimeos\MShop\Service\Provider\Decorator\Base
    implements \Aimeos\MShop\Service\Provider\Decorator\Iface
	public function process( \Aimeos\MShop\Order\Item\Iface $order, array $params = [] ) : ?\Aimeos\MShop\Common\Helper\Form\Iface
		$ref = ['order/base/address', 'order/base/coupon', 'order/base/product', 'order/base/service'];
		$orderBaseItem = $this->getOrderBase( $order->getBaseId(), $ref );
		$form = $this->getProvider()->process( $order, $params );
		return $form;
Re: Currency conversion
Post by aimeos » 02 Apr 2023, 11:24
The only way this will work is if you overwrite the getAmount() method in a new provider extending from the PayPalExpress payment service provider and convert the currency amount right before it's sent to PayPal:
- https://github.com/aimeos/aimeos-core/b ... #L308-L342
For example in MShop/Service/Provider/Payment/MyPayPal.php
class MyPayPal extends PayPalExpress
	protected function getAmount( \Aimeos\MShop\Price\Item\Iface $price, bool $costs = true, bool $tax = true,
		int $precision = null ) : string
Use "MyPayPal" as name in the service panel as payment provider name.
kdim95
Post by kdim95 » 03 Apr 2023, 16:02
Thank you, your suggestion helped me a lot!
I overrided the getAmount() and send() methods.
Inside the getAmount() I check if $price->getCurrencyId() is the currency ID I want to modify and convert the $amount to EUR using a fixed conversion rate.
Inside the send() method I check if there are the keys CURRENCYCODE and PAYMENTREQUEST_0_CURRENCYCODE and change the strings to EUR.
If the conversion rate is not fixed, another method will be required to get the correct conversion rate dynamically from somewhere, but I am unsure if the payment will pass if the callback comes and the conversion has changed.
namespace Aimeos\MShop\Service\Provider\Payment;
class PayPalExpressCustom extends PayPalExpress
	private $conversionRate = <THE CONVERSION RATE>; // Currency conversion rate
	// Convert <THE CURRENCY CODE> to EUR
	protected function getAmount( \Aimeos\MShop\Price\Item\Iface $price, bool $costs = true, bool $tax = true, int $precision = null ) : string
		$amount = parent::getAmount( $price, $costs, $tax, $precision );
		if( $price->getCurrencyId() !== '<THE CURRENCY CODE>' ) {
			return $amount;
		$amount = $amount / $this->conversionRate;
		return number_format( $amount, $precision !== null ? $precision : $price->getPrecision(), '.', '' );;
	// Change <THE CURRENCY CODE> currency code to EUR
	public function send( string $target, string $method, string $payload ) : string
		$values = [];
		parse_str( $payload, $values );
		if( isset( $values['CURRENCYCODE'] ) && $values['CURRENCYCODE'] === '<THE CURRENCY CODE>' )
			$values['CURRENCYCODE'] = 'EUR';
		if( isset( $values['PAYMENTREQUEST_0_CURRENCYCODE'] ) && $values['PAYMENTREQUEST_0_CURRENCYCODE'] === '<THE CURRENCY CODE>' ) {
			$values['PAYMENTREQUEST_0_CURRENCYCODE'] = 'EUR';
		$payload = http_build_query( $values, '', '&' );
		return parent::send($target, $method, $payload);
