Catalog index not updating
kdim95
Post by kdim95 » 04 Apr 2023, 13:06
PHP Version: 8.2.4
Environment: Linux
My catalog index is not updating.
I am importing and updating products the following way:
// Create managers
$product_manager = \Aimeos\MShop::create( $this->context, 'product' );
$catalog_manager = \Aimeos\MShop::create( $this->context, 'catalog' );
$index_manager = \Aimeos\MShop::create( $this->context, 'index' );
// Begin product changes
$product_manager->begin();
// Get product
$product_item = $product_manager->get( <product id> );
// Remove category list items from product
$category_list_items = $product_item->getListItems( 'catalog', 'default', null, false );
$product_item->deleteListItems( $category_list_items );
// Get category item
$category_item = $catalog_manager->get( <category id> );
// Add category list item to product
$category_list_item = $catalog_manager->createListItem();
$product_item->addListItem( 'catalog', $category_list_item, $category_item );
// Save product
$product_manager->save( $product_item );
// Commit product changes
$product_manager->commit();
I'm using ElasticSearch indexing.
'mshop' => [
	'index' => [
		'manager' => [
			'name' => 'ElasticIndex', // Only index existing products from DB
The categories just won't appear in the frontend until I do a full index rebuild, using the following console command:
php artisan aimeos:jobs index/rebuild
What am I doing wrong here?
By the way the example code here is a very cut down version of what I'm actually using, which includes adding attributes, properties, stock items, checking if the individual items exist before updating them, etc.
Re: Catalog index not updating
Post by aimeos » 07 Apr 2023, 08:27
Use the index manager instead of the product manager because the index manager saves the products and updates the index in one step:
$index_manager->begin();
// Get products
$filter = $product_manager->filter()->add( 'product.id', '==', <product ids> );
$product_items = $product_manager->search( $filter );
// Update products ...
// Save products
$index_manager->save( $product_items );
// Finally commit all product changes after e.g. 100 products
$index_manager->commit();
Also, you can speed up the import drastically if you use optimized code like this one:
https://github.com/aimeos/ai-controller ... #L133-L140
kdim95
Post by kdim95 » 07 Apr 2023, 13:15
Thank you!
By the way I think there is a problem when saving single product items as opposed to arrays of product items
$index_manager->begin(); // This is not taken in account
$index_manager->save( $single_product_item ); // Item is saved here without calling $manager->commit()
$index_manager->commit(); // This is not taken in account
kdim95
Post by kdim95 » 07 Apr 2023, 14:42
What would you say is the average time in seconds to save and index 5,000 products?
It currently takes about 1 minute, maybe less for me.
There are properties, attribute items, catalog items, configs, text items, media items, price items added for each product that is being saved using $index_manager->save( $products ).
Post by aimeos » 11 Apr 2023, 07:32
It depends a bit on your hardware but you may get more products updated in the same timeframe with optimized code and when saving batches of products at once (250-500 is a good value if you have no memory contraints).
