User groups for Decorators?
kdim95
Post by kdim95 » 06 Apr 2023, 12:35
Laravel framework version: 9.52.5
PHP Version: 8.2.4
Environment: Linux
Is it possible to have a decorator work only for a specific user group?
If not, what is the best way to check if a user is in the admin group inside a decorator?
Re: User groups for Decorators?
Post by aimeos » 07 Apr 2023, 08:43
Where do you want to use the decorator? Frontend? Admin backend?
kdim95
Post by kdim95 » 07 Apr 2023, 08:53
Hello, I wanted to use the decorator in the backend.
I think I already found the solution.
Solution if you want to use the group ID:
$context = $this->context();
$customer = \Aimeos\MShop::create( $context, 'customer' )->get( $context->user() );
$groups = $customer->getGroups();
$isAdmin = in_array( 1, $groups );
$isEditor = in_array( 2, $groups );
dump( 'isAdmin', $isAdmin );
dump( 'isEditor', $isEditor );
dump( 'isSuper', $customer->isSuper() );
Solution if you want to use the group code:
$groups = $customer->getRefItems( 'customer/group' );
$isAdmin = (bool) $groups->find( function( $value, $key ) {
	return $value->getCode() === 'admin';
$isEditor = (bool) $groups->find( function( $value, $key ) {
	return $value->getCode() === 'editor';
But I don't need this code anymore, because I've created the decorator in a different way.
It used to mess with order modifications in the frontend, but I think it's fixed now.
The decorator is in a different location now -> Aimeos\Admin\JQAdm\Common\Decorator.
Used to be in Aimeos\MShop\Common\Manager\Decorator.
Post by aimeos » 07 Apr 2023, 09:15
Don't mess with group IDs and use the access() view helper instead:
https://aimeos.org/docs/latest/infrastr ... ew/#access
kdim95
Post by kdim95 » 07 Apr 2023, 09:37
aimeos wrote: 07 Apr 2023, 09:15 Don't mess with group IDs and use the access() view helper instead:
I tried this, but in the following case the user is in the admin group, but not in the editor group.
$view = $this->view();
dump( $view->access( ['editor'] ) );
Whatever I put in the array, be it 'editor', 'admin', it always returns true.
This is done in a decorator Aimeos\Admin\JQAdm\Common\Decorator\<My Decorator>::save()
Post by aimeos » 11 Apr 2023, 07:07
kdim95 wrote: 07 Apr 2023, 09:37 I tried this, but in the following case the user is in the admin group, but not in the editor group.
It's OK to do that in a decorator or a template - that doesn't matter.
If it returns true in both cases, then the user must be in both groups because the code for checking is very easy:
https://github.com/aimeos/aimeos-base/b ... rd.php#L52
