Vendor for the basket product
Justus
Post by Justus » 07 Apr 2023, 10:28
I'm using JSONAPI and tried to set the vendor as described in the add products documentation , but it doesn't work
I'm using aimeos 2022.10
In 2021.x I have used supplier ID for supplier key and it works fine.
Now in the code I didn't find that the vendor from the request is used, the label from the site object is always set
https://github.com/aimeos/aimeos-core/b ... d.php#L769
Is there a way to set the vendor name without customizing the copyFrom method? It seemed to me that this should work the same as with the supplier in previous versions.
Re: Vendor for the basket product
Post by aimeos » 11 Apr 2023, 07:28
The basket parameters have been simplified a bit and the vendor parameter has been removed in favor of the siteid parameter. If you want to add the supplier name instead, you have to overwrite the copyFrom() method now.
Post by aimeos » 11 Apr 2023, 09:16
The documentation has been updated accordingly:
https://aimeos.org/docs/latest/frontend ... d-products
Justus
Post by Justus » 11 Apr 2023, 10:09
ok, thanks
