Admin order decorator - Service attributes not updating after $client->save()
kdim95
Post by kdim95 » 09 Apr 2023, 23:15
PHP Version: 8.2.4
Environment: Linux
I can't seem to get the updated service attributes inside the admin order decorator.
Config:
'admin' => [
	'jqadm' => [
		'order' => [
			'decorators' => [ 'MyDecorator' ],
Decorator:
namespace Aimeos\Admin\JQAdm\Common\Decorator;
class MyDecorator
	extends \Aimeos\Admin\JQAdm\Common\Decorator\Base
	public function save() : ?string
		$view = $this->view();
		$client = $this->getClient();
		// Copy the resource so $view->item is available
		$client->copy();
		$item_original = $view->item;
		$return = $client->save();
		$item_changed = $view->item;
		$payment_original = $item_original->getService( 'payment' )->first();
		$payment_changed = $item_changed->getService( 'payment' )->first();
		$payment_attributes_original = $payment_original->getAttributeItems(); // Gets current (not updated)  attributes
		$payment_attributes_changed = $payment_changed->getAttributeItems() // Does not return the updated attributes
		return $return;
kdim95
Re: Admin order decorator - Service attributes not updating after $client->save()
Post by kdim95 » 10 Apr 2023, 08:40
Another problem is that the invoice payment status change is also not reflected when executing $client->save().
I'm trying to get the old and new values of every order element before and after it has been changed in the admin.
Post by aimeos » 11 Apr 2023, 07:41
The save() method stores the updated data in the database but doesn't update the items. If you need the updated items in the end, you have to fetch them from the database.
kdim95
Post by kdim95 » 11 Apr 2023, 15:07
Thanks, that seems to have been the case.
