Review rating count not updating unless index is rebuilt
kdim95
Post by kdim95 » 19 Apr 2023, 11:18
PHP Version: 8.2.4
Environment: Linux
Steps to reproduce:
1) Use ElasticSearch index
2) Add a review to a product
3) Publish the review from the administration
4) The review rating count is not updated in the frontend
5) php artisan aimeos:jobs index/rebuild
6) Review rating count is updated in the frontend
The code I use to get the count of ratings:
$this->detailProductItem->getRatings()
nos3
Re: Review rating count not updating unless index is rebuilt
Post by nos3 » 21 Apr 2023, 14:32
There had been two problems:
- The admin backend used only the product manager to update the ratings, not the index manager
- The ElasticIndex class didn't forward the new rating to the product manager
This has been fixed and new 2022.10.x versions of the aimeos/ai-admin-jqadm and aimeoscom/ai-elastic packages have been released. If you use 2023.04+, use the ".x-dev" version instead until new minor releases are available.
kdim95
Post by kdim95 » 23 May 2023, 08:33
I still haven't solved this problem.
Which files exactly were the problematic ones, because I might have overwritten them.
This is what my composer.json looks like:
    "name": "aimeos/aimeos",
    "description": "Aimeos ecommerce and shop system",
    "keywords": ["aimeos", "ecommerce", "shop", "laravel", "distribution"],
    "license": "MIT",
    "type": "project",
    "repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom"
        "type": "path",
        "url": "packages/*"
        "type": "vcs",
        "url": "https://github.com/kras95/omnipay-borica"
		"type": "composer",
    "require": {
        "php": "^8.0.10",
        "composer-runtime-api": "^2.1",
        "aimeos/ai-cache": "^2022.10",
        "aimeos/ai-catsuggest": "^2022.10",
        "aimeos/ai-client-jsonapi": "2022.10.x-dev",
        "aimeos/ai-payments": "^2022.10",
        "aimeos/aimeos-laravel": "~2022.10",
        "aimeoscom/ai-elastic": "^2022.10",
        "doctrine/dbal": "^3.5",
        "guzzlehttp/guzzle": "^7.2",
        "laravel/breeze": "^1.9",
        "laravel/framework": "^9.2",
        "laravel/sanctum": "^2.14.1",
        "laravel/socialite": "^5.5",
        "laravel/tinker": "^2.7",
        "league/flysystem-aws-s3-v3": "^3.0",
        "league/omnipay": "^3.2",
        "omnipay/paypal": "^3.0",
        "omnipay/stripe": "^3.2"
    "require-dev": {
        "fakerphp/faker": "^1.9.1",
        "laravel/sail": "^1.0.1",
        "mockery/mockery": "^1.4.4",
        "nunomaduro/collision": "^6.1",
        "phpunit/phpunit": "^9.5.10",
        "spatie/laravel-ignition": "^1.0"
    "autoload": {
        "psr-4": {
            "App\\": "app/",
            "Database\\Factories\\": "database/factories/",
            "Database\\Seeders\\": "database/seeders/"
	"exclude-from-classmap": [ "vendor/aimeoscom/ai-elastic/src/MShop/Product/Manager/Elastic.php" ],
	"files": [ "packages/my-extension/src/MShop/Product/Manager/Elastic.php" ]
    "autoload-dev": {
        "psr-4": {
            "Tests\\": "tests/"
    "scripts": {
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover --ansi"
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate --ansi",
            "App\\Composer::configure",
            "@php artisan migrate",
            "App\\Composer::setup",
            "App\\Composer::account",
            "App\\Composer::success"
        "post-update-cmd": [
		"@php artisan vendor:publish --tag=public --force",
		"\\Aimeos\\Shop\\Composer::join"
    "extra": {
        "laravel": {
            "dont-discover": []
    "config": {
        "optimize-autoloader": true,
        "preferred-install": "dist",
        "sort-packages": true,
        "allow-plugins": {
            "php-http/discovery": true
    "minimum-stability": "dev",
    "prefer-stable": true
kdim95
Post by kdim95 » 23 May 2023, 09:28
I think that this may actually be some kind of cache.
I get the reviews like this (network logs):
/jsonapi/review?filter%5Bf_refid%5D=26&sort=-ctime
The reviews are actually taking a bit of time before appearing in the frontend.
kdim95
Post by kdim95 » 23 May 2023, 12:09
I solved it like this:
Decorator:
packages/my-extension/src/MShop/Review/Manager/Decorator/MyDecorator.php
<?php
namespace Aimeos\Client\JsonApi\Review\Decorator;
use Psr\Http\Message\ServerRequestInterface;
use Psr\Http\Message\ResponseInterface;
class MyDecorator
    extends \Aimeos\Client\JsonApi\Common\Decorator\Base
    implements \Aimeos\Client\JsonApi\Common\Decorator\Iface
	 * Remove user review cache
	public function get( ServerRequestInterface $request, ResponseInterface $response ) : \Psr\Http\Message\ResponseInterface
        return parent::get( $request, $response )
                ->withHeader('Cache-Control', 'no-store, no-cache, must-revalidate')
                ->withHeader('Pragma', 'no-cache')
                ->withHeader('Expires', '0');
Config:
packages/my-extension/config/client.php
<?php
return [
	'jsonapi' => [
		'review' => [
			'decorators' => [
				'local' => [ 'MyDecorator' ]
Post by aimeos » 24 May 2023, 09:23
Seems to be some browser caching because the Laravel Jsonapi controller doesn't set any caching headers for GET requests:
https://github.com/aimeos/aimeos-larave ... roller.php
