Getting error In Order
DamanMokha
Post by DamanMokha » 19 Apr 2023, 13:42
I am using the headless version of the application and I am experiencing an issue while placing an order in the API. Although I am getting the order ID when I use the save basket API, when I try to access the admin page, I encounter an attached error. Additionally, when I attempt to save an order using the order ID obtained from saving the basket, the system shows a "no order ID" error, despite the fact that I can see the order ID in the database for the same order.
Called unknown macro "getBaseId" on class "Aimeos\MShop\Order\Item\Standard"
#0 /Users/damanmokha/Projects/cottage-butcher/headless/packages/cottage-buttcher/templates/admin/jqadm/dashboard/item-order-latest.php(101): Aimeos\MShop\Order\Item\Base->__call('getBaseId', Array)
#1 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/aimeos-base/src/View/Standard.php(281): include('/Users/damanmok...')
#2 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/aimeos-base/src/View/Standard.php(263): Aimeos\Base\View\Standard->includeFile('/Users/damanmok...')
#3 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Dashboard/Order/Latest/Standard.php(76): Aimeos\Base\View\Standard->render('dashboard/item-...')
#4 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Base.php(281): Aimeos\Admin\JQAdm\Dashboard\Order\Latest\Standard->search()
#5 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Dashboard/Order/Standard.php(47): Aimeos\Admin\JQAdm\Base->search()
#6 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Base.php(281): Aimeos\Admin\JQAdm\Dashboard\Order\Standard->search()
#7 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Dashboard/Standard.php(83): Aimeos\Admin\JQAdm\Base->search()
#8 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Common/Decorator/Base.php(162): Aimeos\Admin\JQAdm\Dashboard\Standard->search()
#9 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/aimeos/aimeos-laravel/src/Controller/JqadmController.php(230): Aimeos\Admin\JQAdm\Common\Decorator\Base->search()
#10 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): Aimeos\Shop\Controller\JqadmController->searchAction('default', 'dashboard')
#11 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction('searchAction', Array)
#12 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Aimeos\Shop\Controller\JqadmController), 'searchAction')
#13 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#14 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Router.php(798): Illuminate\Routing\Route->run()
#15 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\closure(Object(Illuminate\Http\Request))
#16 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#17 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#18 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#19 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Auth\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure))
#20 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#21 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#23 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#24 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#25 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest(Object(Illuminate\Http\Request), Object(Illuminate\Session\Store), Object(Closure))
#26 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#27 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#28 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#29 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#30 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#31 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#32 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#33 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#34 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#35 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#36 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#37 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\closure(Object(Illuminate\Http\Request))
#38 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#39 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#41 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#42 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#44 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#45 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#46 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#47 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#48 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Http/Middleware/HandleCors.php(62): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#49 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\HandleCors->handle(Object(Illuminate\Http\Request), Object(Closure))
#50 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#51 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#52 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\closure(Object(Illuminate\Http\Request))
#53 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#54 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#55 /Users/damanmokha/Projects/cottage-butcher/headless/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#56 /Users/damanmokha/Projects/cottage-butcher/headless/vendor/laravel/framework/src/Illuminate/Foundation/resources/server.php(16): require_once('/Users/damanmok...')
#57 main
Re: Getting error In Order
Post by aimeos » 19 Apr 2023, 13:51
Which Aimeos version do you use?
DamanMokha
Post by DamanMokha » 19 Apr 2023, 17:09
I am using, 2023.04.1 , Here is composer show output
aimeos-extensions/cottage-buttcher    dev-development Aimeos cottage-buttcher extension
aimeos/ai-admin-graphql               2023.04.2       Aimeos Admin GraphQL API extension
aimeos/ai-admin-jqadm                 2023.04.2       Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm               2023.04.1       Aimeos JSON admin API for backend
aimeos/ai-client-html                 2023.04.1       Aimeos standard HTML frontend
aimeos/ai-client-jsonapi              2023.04.1       Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs                2023.04.1       Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend         2023.04.1       Aimeos business controller logic for frontend
aimeos/ai-controller-jobs             2023.04.1       Aimeos job controllers for long running tasks
aimeos/ai-filesystem                  2023.04.1       Aimeos file system layer extension
aimeos/ai-laravel                     2023.04.1       Laravel adapter for Aimeos e-commerce integr...
aimeos/ai-payments                    2023.04.1       Payment extension for Aimeos e-commerce solu...
aimeos/aimeos-base                    2023.04.1       Aimeos base layer for abstracting from host ...
aimeos/aimeos-core                    2023.04.1       Full-featured e-commerce components for high...
aimeos/aimeos-laravel                 2023.04.1       Professional, full-featured and high perform...
aimeos/macro                          1.0.0           Dynamically extend objects by custom methods
aimeos/map                            3.5.0           Easy and elegant handling of PHP arrays as a...
aimeos/upscheme                       0.8.7           Database schema upgrades made easy
aws/aws-crt-php                       v1.2.1          AWS Common Runtime for PHP
aws/aws-sdk-php                       3.263.12        AWS SDK for PHP - Use Amazon Web Services in...
brick/math                            0.11.0          Arbitrary-precision arithmetic library
clue/stream-filter                    v1.6.0          A simple and modern approach to stream filte...
dflydev/dot-access-data               v3.0.2          Given a deep data structure, access data by ...
doctrine/cache                        2.2.0           PHP Doctrine Cache library is a popular cach...
doctrine/dbal                         3.6.2           Powerful PHP database abstraction layer (DBA...
doctrine/deprecations                 v1.0.0          A small layer on top of trigger_error(E_USER...
doctrine/event-manager                2.0.0           The Doctrine Event Manager is a simple PHP e...
doctrine/inflector                    2.0.6           PHP Doctrine Inflector is a small library th...
doctrine/lexer                        3.0.0           PHP Doctrine Lexer parser library that can b...
dragonmantank/cron-expression         v3.3.2          CRON for PHP: Calculate the next or previous...
egulias/email-validator               4.0.1           A library for validating emails against seve...
enshrined/svg-sanitize                0.16.0          An SVG sanitizer for PHP
ezyang/htmlpurifier                   v4.16.0         Standards compliant HTML filter written in PHP
fakerphp/faker                        v1.21.0         Faker is a PHP library that generates fake d...
filp/whoops                           2.15.2          php error handling for cool kids
firebase/php-jwt                      v6.4.0          A simple library to encode and decode JSON W...
fruitcake/php-cors                    v1.2.0          Cross-origin resource sharing library for th...
google/auth                           v1.26.0         Google Auth Library for PHP
google/cloud-core                     v1.49.4         Google Cloud PHP shared dependency, providin...
google/cloud-storage                  v1.30.2         Cloud Storage Client for PHP
google/crc32                          v0.1.0          Various CRC32 implementations
graham-campbell/result-type           v1.1.1          An Implementation Of The Result Type
guzzlehttp/guzzle                     7.5.1           Guzzle is a PHP HTTP client library
guzzlehttp/promises                   1.5.2           Guzzle promises library
guzzlehttp/psr7                       2.5.0           PSR-7 message implementation that also provi...
guzzlehttp/uri-template               v1.0.1          A polyfill class for uri_template of PHP
hamcrest/hamcrest-php                 v2.0.1          This is the PHP port of Hamcrest Matchers
laminas/laminas-diactoros             2.25.2          PSR HTTP Message implementations
laravel/breeze                        v1.20.2         Minimal Laravel authentication scaffolding w...
laravel/framework                     v10.8.0         The Laravel Framework.
laravel/pint                          v1.9.0          An opinionated code formatter for PHP.
laravel/sail                          v1.21.4         Docker files for running a basic Laravel app...
laravel/sanctum                       v3.2.1          Laravel Sanctum provides a featherweight aut...
laravel/serializable-closure          v1.3.0          Laravel Serializable Closure provides an eas...
laravel/tinker                        v2.8.1          Powerful REPL for the Laravel framework.
lcobucci/clock                        3.0.0           Yet another clock abstraction
lcobucci/jwt                          4.3.0           A simple library to work with JSON Web Token...
league/commonmark                     2.4.0           Highly-extensible PHP Markdown parser which ...
league/config                         v1.2.0          Define configuration arrays with strict sche...
league/flysystem                      3.14.0          File storage abstraction for PHP
league/flysystem-aws-s3-v3            3.13.0          AWS S3 filesystem adapter for Flysystem.
league/flysystem-azure-blob-storage   3.13.0
league/flysystem-google-cloud-storage 3.13.0          Google Cloud Storage adapter for Flysystem.
league/mime-type-detection            1.11.0          Mime-type detection for Flysystem
microsoft/azure-storage-blob          1.5.4           This project provides a set of PHP client li...
microsoft/azure-storage-common        1.5.2           This project provides a set of common code s...
mockery/mockery                       1.5.1           Mockery is a simple yet flexible PHP mock ob...
moneyphp/money                        v4.1.1          PHP implementation of Fowler's Money pattern
monolog/monolog                       3.3.1           Sends your logs to files, sockets, inboxes, ...
mtdowling/jmespath.php                2.6.1           Declaratively specify how to extract element...
myclabs/deep-copy                     1.11.1          Create deep copies (clones) of your objects
namshi/jose                           7.2.3           JSON Object Signing and Encryption library f...
nesbot/carbon                         2.66.0          An API extension for DateTime that supports ...
nette/schema                          v1.2.3          📐 Nette Schema: validating data structure...
nette/utils                           v4.0.0          🛠  Nette Utils: lightweight utilities for...
nikic/php-parser                      v4.15.4         A PHP parser written in PHP
nunomaduro/collision                  v7.5.0          Cli error handling for console/command-line ...
nunomaduro/termwind                   v1.15.1         Its like Tailwind CSS, but for the console.
nyholm/psr7                           1.6.1           A fast PHP7 implementation of PSR-7
omnipay/common                        v3.2.0          Common components for Omnipay payment proces...
omnipay/stripe                        v3.2.0          Stripe driver for the Omnipay payment proces...
phar-io/manifest                      2.0.3           Component for reading phar.io manifest infor...
phar-io/version                       3.2.1           Library for handling version information and...
php-http/curl-client                  2.2.1           PSR-18 and HTTPlug Async client with cURL
php-http/discovery                    1.15.3          Finds and installs PSR-7, PSR-17, PSR-18 and...
php-http/httplug                      2.4.0           HTTPlug, the HTTP client abstraction for PHP
php-http/message                      1.14.0          HTTP Message related tools
php-http/message-factory              1.1.0           Factory interfaces for PSR-7 HTTP Message
php-http/promise                      1.1.0           Promise used for asynchronous HTTP requests
php-open-source-saver/jwt-auth        2.1.0           JSON Web Token Authentication for Laravel an...
phpoption/phpoption                   1.9.1           Option Type for PHP
phpunit/php-code-coverage             10.1.1          Library that provides collection, processing...
phpunit/php-file-iterator             4.0.1           FilterIterator implementation that filters f...
phpunit/php-invoker                   4.0.0           Invoke callables with a timeout
phpunit/php-text-template             3.0.0           Simple template engine.
phpunit/php-timer                     6.0.0           Utility class for timing
phpunit/phpunit                       10.1.1          The PHP Unit Testing framework.
psr/cache                             3.0.0           Common interface for caching libraries
psr/clock                             1.0.0           Common interface for reading the clock.
psr/container                         2.0.2           Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher                  1.0.0           Standard interfaces for event handling.
psr/http-client                       1.0.2           Common interface for HTTP clients
psr/http-factory                      1.0.2           Common interfaces for PSR-7 HTTP message fac...
psr/http-message                      1.1             Common interface for HTTP messages
psr/log                               3.0.0           Common interface for logging libraries
psr/simple-cache                      3.0.0           Common interfaces for simple caching
psy/psysh                             v0.11.15        An interactive shell for modern PHP.
ralouphie/getallheaders               3.0.3           A polyfill for getallheaders.
ramsey/collection                     2.0.0           A PHP library for representing and manipulat...
ramsey/uuid                           4.7.4           A PHP library for generating and working wit...
rize/uri-template                     0.3.5           PHP URI Template (RFC 6570) supports both ex...
sebastian/cli-parser                  2.0.0           Library for parsing CLI options
sebastian/code-unit                   2.0.0           Collection of value objects that represent t...
sebastian/code-unit-reverse-lookup    3.0.0           Looks up which function or method a line of ...
sebastian/comparator                  5.0.0           Provides the functionality to compare PHP va...
sebastian/complexity                  3.0.0           Library for calculating the complexity of PH...
sebastian/diff                        5.0.1           Diff implementation
sebastian/environment                 6.0.1           Provides functionality to handle HHVM/PHP en...
sebastian/exporter                    5.0.0           Provides the functionality to export PHP var...
sebastian/global-state                6.0.0           Snapshotting of global state
sebastian/lines-of-code               2.0.0           Library for counting the lines of code in PH...
sebastian/object-enumerator           5.0.0           Traverses array structures and object graphs...
sebastian/object-reflector            3.0.0           Allows reflection of object attributes, incl...
sebastian/recursion-context           5.0.0           Provides functionality to recursively proces...
sebastian/type                        4.0.0           Collection of value objects that represent t...
sebastian/version                     4.0.1           Library that helps with managing the version...
spatie/backtrace                      1.4.0           A better backtrace
spatie/flare-client-php               1.3.6           Send PHP errors to Flare
spatie/ignition                       1.5.0           A beautiful error page for PHP applications.
spatie/laravel-ignition               2.1.0           A beautiful error page for Laravel applicati...
symfony/console                       v6.2.8          Eases the creation of beautiful and testable...
symfony/css-selector                  v6.2.7          Converts CSS selectors to XPath expressions
symfony/deprecation-contracts         v3.2.1          A generic function and convention to trigger...
symfony/error-handler                 v6.2.9          Provides tools to manage errors and ease deb...
symfony/event-dispatcher              v6.2.8          Provides tools that allow your application c...
symfony/event-dispatcher-contracts    v3.2.1          Generic abstractions related to dispatching ...
symfony/finder                        v6.2.7          Finds files and directories via an intuitive...
symfony/http-foundation               v6.2.8          Defines an object-oriented layer for the HTT...
symfony/http-kernel                   v6.2.9          Provides a structured process for converting...
symfony/mailer                        v6.2.8          Helps sending emails
symfony/mime                          v6.2.7          Allows manipulating MIME messages
symfony/options-resolver              v6.2.7          Provides an improved replacement for the arr...
symfony/polyfill-ctype                v1.27.0         Symfony polyfill for ctype functions
symfony/polyfill-intl-grapheme        v1.27.0         Symfony polyfill for intl's grapheme_* funct...
symfony/polyfill-intl-idn             v1.27.0         Symfony polyfill for intl's idn_to_ascii and...
symfony/polyfill-intl-normalizer      v1.27.0         Symfony polyfill for intl's Normalizer class...
symfony/polyfill-mbstring             v1.27.0         Symfony polyfill for the Mbstring extension
symfony/polyfill-php56                v1.20.0         Symfony polyfill backporting some PHP 5.6+ f...
symfony/polyfill-php72                v1.27.0         Symfony polyfill backporting some PHP 7.2+ f...
symfony/polyfill-php80                v1.27.0         Symfony polyfill backporting some PHP 8.0+ f...
symfony/polyfill-uuid                 v1.27.0         Symfony polyfill for uuid functions
symfony/process                       v6.2.8          Executes commands in sub-processes
symfony/psr-http-message-bridge       v2.1.4          PSR HTTP message bridge
symfony/routing                       v6.2.8          Maps an HTTP request to a set of configurati...
symfony/service-contracts             v3.2.1          Generic abstractions related to writing serv...
symfony/string                        v6.2.8          Provides an object-oriented API to strings a...
symfony/translation                   v6.2.8          Provides tools to internationalize your appl...
symfony/translation-contracts         v3.2.1          Generic abstractions related to translation
symfony/uid                           v6.2.7          Provides an object-oriented API to generate ...
symfony/var-dumper                    v6.2.8          Provides mechanisms for walking through any ...
symfony/yaml                          v6.2.7          Loads and dumps YAML files
tecnickcom/tcpdf                      6.6.2           TCPDF is a PHP class for generating PDF docu...
theseer/tokenizer                     1.2.1           A small library for converting tokenized PHP...
tijsverkoyen/css-to-inline-styles     2.2.6           CssToInlineStyles is a class that enables yo...
vlucas/phpdotenv                      v5.5.0          Loads environment variables from `.env` to `...
voku/portable-ascii                   2.0.1           Portable ASCII library - performance optimiz...
webmozart/assert                      1.11.0          Assertions to validate method input/output w...
webonyx/graphql-php                   v15.2.5         A PHP port of GraphQL reference implementation
Post by aimeos » 21 Apr 2023, 14:47
Seems like you've upgraded from an earlier version and have overwritten the "admin/jqadm/dashboard/item-order-latest.php" template. In 2023.04+, the order and order/base domains have been merged and the template for 2023.04+ now looks like this one:
https://github.com/aimeos/ai-admin-jqad ... latest.php
