How to display custom media in basket view?
columbo
Post by columbo » 04 May 2023, 20:41
we are using two different product media types ("default" and "custom").
On basket and checkout page the custom media should be displayed.
How can we select the custom media type here (\packages\myext\templates\client\html\common\summary\detail.php):
<img src="<?= $this->content( $product->getMediaUrl() ) ?>" />
e.g. for favorite view (\packages\myext\templates\client\html\account\favorite\body.php) we used:
$productItem->getRefItems('media', 'custom', 'default')
But this does not work for the basket view.
Thank you!
Re: How to display custom media in basket view?
Post by aimeos » 07 May 2023, 11:46
You need to overwrite the copyFrom() method in order product item:
https://github.com/aimeos/aimeos-core/b ... #L747-L773
In the next versions, you will able to be overwrite the code by using macros:
\Aimeos\MShop\Order\Item\Product\Standard::macro( 'copyFrom', function( \Aimeos\MShop\Product\Item\Iface $product ) : \Aimeos\MShop\Order\Item\Base\Product\Iface {
	return $this->setModified();
columbo
Post by columbo » 16 Nov 2023, 11:08
as the file has changed with the new version 2023.10 I think copyFrom() in file /aimeos-core/src/MShop/Order/Item/Product/Standard.php is the right one.
As suggested, I tried with macro in /app/ProvidersApp/ServiceProvider.php and changed the image form "default" to "custom"
public function boot()
            $this->fromArray( $values );
            $this->setSiteId( $product->getSiteId() );
            $this->setProductCode( $product->getCode() );
            $this->setProductId( $product->getId() );
            $this->setType( $product->getType() );
            $this->setScale( $product->getScale() );
            $this->setTarget( $product->getTarget() );
            $this->setName( $product->getName() );
            if( $item = $product->getRefItems( 'text', 'basket', 'default' )->first() ) {
                $this->setDescription( $item->getContent() );
            if( $item = $product->getRefItems( 'media', 'custom', 'default' )->first() ) {
                $this->setMediaUrl( $item->getPreview() );
            if( $item = $product->getSiteItem() ) {
                $this->setVendor( $item->getLabel() );
laravel.log after adding an item to basekt:
ERROR: Call to undefined method App\Providers\AppServiceProvider::fromArray() {"userId":1,"exception":"[object] (Error(code: 0): Call to undefined method App\\Providers\\AppServiceProvider::fromArray() at /app/Providers/AppServiceProvider.php:32)
[stacktrace]
#0 /vendor/aimeos/aimeos-core/src/MShop/Order/Item/Product/Standard.php(766): App\\Providers\\AppServiceProvider->App\\Providers\\{closure}()
#1 /vendor/aimeos/ai-controller-frontend/src/Controller/Frontend/Basket/Standard.php(346): Aimeos\\MShop\\Order\\Item\\Product\\Standard->copyFrom()
#2 /vendor/aimeos/ai-controller-frontend/src/Controller/Frontend/Basket/Decorator/Category.php(59): Aimeos\\Controller\\Frontend\\Basket\\Standard->addProduct()
#3 /vendor/aimeos/ai-controller-frontend/src/Controller/Frontend/Basket/Decorator/Bundle.php(44): Aimeos\\Controller\\Frontend\\Basket\\Decorator\\Category->addProduct()
#4 /vendor/aimeos/ai-controller-frontend/src/Controller/Frontend/Basket/Decorator/Select.php(43): Aimeos\\Controller\\Frontend\\Basket\\Decorator\\Bundle->addProduct()
#5 /vendor/aimeos/ai-client-html/src/Client/Html/Basket/Standard/Standard.php(218): Aimeos\\Controller\\Frontend\\Basket\\Decorator\\Select->addProduct()
Thank you
Post by aimeos » 17 Nov 2023, 16:11
Two mistakes:
1.) The function wasn't bound to the order product item object so $this referred to the AppServiceProvider where you've added the closure. This is now fixed and you need to execute:
composer req aimeos/aimeos-core:2023.10.x-dev
2.) You are missing one line in your function:
$values = $product->toArray();
columbo
Post by columbo » 20 Nov 2023, 21:46
for the sake of completeness - there was a third mistake in return parameter:
wrong: \Aimeos\MShop\Order\Item\Base\Product\Iface
-> correct: \Aimeos\MShop\Order\Item\Product\Iface
this code it is working fine:
        \Aimeos\MShop\Order\Item\Product\Standard::macro( 'copyFrom', function( \Aimeos\MShop\Product\Item\Iface $product ) : \Aimeos\MShop\Order\Item\Product\Iface {
Thank you!
