Filtering orders by service attribute not working
kdim95
Post by kdim95 » 19 May 2023, 13:58
PHP Version: 8.2.4
Environment: Linux
Filtering orders by service attributes is not working.
I tried with "Service attribute code" and "Service attribute value".
There are no results, but I know that an order exists with the attribute.
How to reproduce:
  • Go to the orders section /admin/default/jqadm/search/order
  • Click on the magnifying glass to open the search modal
    • Select "Service attribute value"
    • Select "=="
    • Input an existing service attribute value added through the order
Result: There are no search results, but I know for a fact that there is an order with the service attribute value.
kdim95
Re: Filtering orders by service attribute not working
Post by kdim95 » 19 May 2023, 22:26
I've been digging and apparently you have to put the attribute value in quotes in the input field :o.
It's getting saved like that in the database.
This is like this because the values are saved as json in the database right?
The quotes should be added to the attribute value automatically when filtering.
Post by aimeos » 20 May 2023, 08:29
Yes, the data is JSON encoded and can be an array or an object too ("[...]" or "{...}") so adding quotes by default won't help.
There are only two possible options:
1.) Use a LIKE search ("%val%") which is extremely slow when the number of orders is high
2.) Remove the ability to search for product/service attributes
kdim95
Post by kdim95 » 22 May 2023, 09:10
I think the problem might be in the backend (the "list.php" template file for the orders), perhaps I'm missing a config that adds the quotes automatically when searching for attribute values? I have attempted to search for attribute values on a clean installation of Aimeos and I get the same result there, you simply have to add the quotes if you search for attribute values. It seems counter intuitive and I have been searching for a while before actually looking at the database and SQL, finding out with surprise that the attribute is being saved with quotes and that it's being queried without any quotes.
Post by aimeos » 24 May 2023, 09:06
Like said, order product/service attribute values can also be arrays or objects ("[...]" or "{...}") and adding quotes automatically, the search won't find anything too.
kdim95
Post by kdim95 » 26 May 2023, 08:14
Perhaps a solution would be if json_decode fails on the input, the input should be enquoted?
I need to check where exactly it's being parsed.
