New media items not being added if ->deleteListItems() is used beforehand.
kdim95
Post by kdim95 » 22 May 2023, 13:43
PHP Version: 8.2.4
Environment: Linux
Why are the new list items not added if I use deleteListItems() on the old list items beforehand?
The goal is to clear old media list items of a specific type and then add them anew.
$media_list_items = $product_item->getListItems( 'media', 'default', 'page', false );
$product_item->deleteListItems( $media_list_items, true ); // New media list items are not added if this method is used
if( isset( $book_info['pages'] ) && sizeof( $book_info['pages'] ) > 0 ) {
	foreach( $book_info['pages'] as $page ) {
		$parts = explode( "/", $page );
		$label = end( $parts );
		$media_item = $media_manager->create();
		$media_item->setType('page');
		$media_item->setDomain( 'product' );
		$media_item->setUrl( $page );
		$media_item->setPreview( $page );
		$media_item->setMimeType( 'image/jpeg' );
		$media_item->setLabel( $label );
		$media_list_item = $product_manager->createListItem();
		$product_item->addListItem( 'media', $media_list_item, $media_item );
Re: New media items not being added if ->deleteListItems() is used beforehand.
Post by aimeos » 24 May 2023, 09:10
Are you sure that addListItem() is actually called?
If you remove all items first and add them again afterwards, it will be pretty slow due to the amount of changes in the database. In the Aimeos code base, list and domain items are reused as often as possible to minimize database changes and to speed up imports.
kdim95
Post by kdim95 » 25 May 2023, 10:57
I'm pretty sure that addListItem() is called, because if I remove deleteListItems(), the items are added.
I think it's some kind of conflict, because items are marked for deletion before they are even added.
Removing all items and re-adding them with the updated ones (if there are changes) simplifies the process and the amount of code for me.
Otherwise I will have to go through every individual file and compare the file names or file sizes, etc.
Also I won't be using this all the time, so it shouldn't take too much resources.
Post by aimeos » 26 May 2023, 09:59
Removing referenced items is done here:
https://github.com/aimeos/aimeos-core/b ... p#L97-L139
They are then returned here:
https://github.com/aimeos/aimeos-core/b ... #L153-L166
And finally deleted here:
https://github.com/aimeos/aimeos-core/b ... #L254-L274
Maybe your can find out now why you have that behavior.
