remove decimal value from price
VirtualSpy
Post by VirtualSpy » 24 May 2023, 13:21
laravel version 9.48.0 , Aimeos version 2022.10.4 and PHP version 8.1.3 (Win)
I changed the "value" column type from decimal to int from table mshop_price & mshop_index_price but the price is still showing in decimal. why?
I also checked this template using die dump (dd) here getting decimal value https://github.com/aimeos/ai-client-htm ... 70C3-L77C1
on function getValue() return the value using function formatNumber() . and precision value
$priceItem->getPrecision()
is getting 2 , from here
https://github.com/aimeos/aimeos-core/blob/master/src/MShop/Price/Manager/Standard.php#LL330C3-L331C1
now using config anyone can change the precision value :)
And sorry Aimeos before getting a response from you I found the solution so, I edited my post again and again.
Re: remove decimal value from price
Post by aimeos » 25 May 2023, 06:29
Number formatting is done in the Number view helper:
https://github.com/aimeos/aimeos-base/b ... hp#L46-L57
Set the number of decimals with that config option:
mshop/price/precision = 0
