Stripe Payment Gateway
DamanMokha
Post by DamanMokha » 26 May 2023, 04:33
I'm using the headless version of the platform and working with JSON APIs. I've installed the Stripe gateway package and enabled the service. However, I'm having trouble finding documentation on how to use it. I've added Stripe as a service in the basket, but I can't find a link to proceed with the payment.
Could you please provide instructions on how to use your Stripe package for payment processing via API?
Thank you.
Re: Stripe Payment Gateway
Post by aimeos » 27 May 2023, 08:47
If you are using the Aimeos headless distribution, you can't use any of the Omnipay drivers as they need the HTML frontend. For pure PWA JS applications, you have to use JS-only solutions like Stripe JS, which you have to add to your PWA yourself.
