Extend Basket API
DamanMokha
Extend Basket API
Post by DamanMokha » 26 May 2023, 04:40
I'm currently working with the headless version and have created an Aimeos extension. In this extension, I have added a few fields using decorators. However, I would like to include some custom-calculated fields in the Basket API that provide the exact total amount by performing calculations. Currently, the Basket API sends costs, prices, and rebates separately.
Essentially, my question is how to extend the Basket API to incorporate custom dynamic fields.
Thank you for your assistance.
Re: Extend Basket API
Post by aimeos » 27 May 2023, 08:53
You can use basket plugins to modify the basket content and set properties you have defined in decorators:
https://aimeos.org/docs/latest/provider ... t-plugins/
