Catalog>Product>text description with color
WGSF
Post by WGSF » 30 May 2023, 14:42
Laravel 10, Aimeos 2022, php 8.1
Is there a way to set colored text (or use html tag) in long or short description of a product ?
kdim95
Re: Catalog>Product>text description with color
Post by kdim95 » 31 May 2023, 08:33
You can read about the ckeditor configuration here:
https://aimeos.org/docs/2022.x/admin/jq ... #customize
By default only the tags div, p, span are allowed.
You can edit the HTML by clicking the three dots on the top right of the editor window and clicking "Source".
By default you can only add classes, no styles, no attributes, but you can override the config in your extension:
/packages/your-extension/themes/admin/jqadm/custom.js
You put this code in your custom.js and change what you want:
Aimeos.ckeditor.htmlSupport = {
  allow: [{
    attributes: false,
    classes: true,
    styles: false,
  disallow: []
WGSF
Post by WGSF » 31 May 2023, 19:42
Thanks a lot for that complete answer
