I am unable to import test products using cronjobs, tried different settings.
ivanessans
Post by ivanessans » 30 May 2023, 18:38
Hi all!
To import products, I used the instructions at this link: https://aimeos.org/docs/2023.x/cronjobs ... est-import
I also want to display my settings file:
	'jobs' => [
		'product' => [
			'import' => [
				'csv' => [
					'location' => public_path( '/aimeos/products-import-example.csv' ),
					'container' => [
						'type' => 'Directory',
						'content' => 'CSV',
					'skip-lines' => 1,
			'export' => [
				'location' => public_path('aimeos')
In the file "product-import-example.csv" I replaced "path/to/image2.jpg" with "".
Run command from terminal:
> php artisan aimeos:jobs "product/import/csv" "default"
Unfortunately, I did not see an error, and the products were not displayed in the admin panel at my-shop.ru/admin/default/jqadm/search/product?locale=en
Throws an error only if there is no connection to the database (server not enabled).
However, the command run from the terminal was completed successfully:
> php artisan aimeos:jobs "product/export/sitemap" "default"
Versions:
aimeos-laravel - 2023.04
Laravel - 10.12.0
PHP - 8.1
MySQL - 8.0
Windows 10
Please tell me how to import products?
ivanessans
Re: I am unable to import test products using cronjobs, tried different settings.
Post by ivanessans » 03 Jun 2023, 10:45
Please HELP solve the problem! Tried different options. I have no one else to turn to.
The site is loading. There is access to the database. Can't import products.
Post by aimeos » 03 Jun 2023, 11:47
Your location path is wrong. If you've upgraded from 2022.x to 2023.x, it changes from an absolute path to a relative path within the virtual file system defined here:
https://github.com/aimeos/aimeos/blob/m ... #L115-L118
By default (without your configuration), it would be:
./storage/import/product/
Remove these lines in your config and place your file in the directory mentioned above to import your file:
'container' => [
	'content' => 'CSV',
ivanessans
Post by ivanessans » 04 Jun 2023, 14:26
Thanks, it worked!
syedaliiftikhar
Post by syedaliiftikhar » 19 Apr 2024, 23:04
I'm also not able to import any product, no error is showing.
Followed the documentation and above suggestion as well but nothing worked for me
Laravel 11.4.0
Aimeos 2024.4
PHP 8.3.6
Ubuntu 20.04.3 LTS
Post by aimeos » 21 Apr 2024, 10:14
Beginning with 2024.04.x, the files are expected to be in a sub-directory named like the site code so the files can be imported for different sites. See: https://aimeos.org/docs/latest/cronjobs ... e-location
