Use grapesjs CMS editor to create an editable footer?
kdim95
Post by kdim95 » 01 Jun 2023, 09:48
Laravel framework version: 10.12.0
Aimeos Laravel version: ~2023.04
PHP Version: 8.2.6
Environment: Linux
I want to create a custom footer section that can be edited in the CMS editor, or create a new admin module that does this and uses the same grapesjs editor. What is the best way to do this?
Re: Use grapesjs CMS editor to create an editable footer?
Post by aimeos » 03 Jun 2023, 11:42
The GrapesJS CMS editor enables you to create content for each URL but a footer is the same for all pages. Thus, the CMS panel won't help you much in that case. You can create an own panel where you include GrapesJS yourself and whose content you can add in the base Blade template as footer.
