How to access to products weight
WGSF
Post by WGSF » 12 Jun 2023, 12:31
Laravel 10, aimeos 2022, php 8.2
I created a Delivery provider in order to override calcPrice method.
It works find, I can access to each product in the basket (access to IDs, prices, descriptions...).
But, How can I access to product weight from calcPrice method ?
Aimeos recommendation ?
WGSF
Re: How to access to products weight
Post by WGSF » 12 Jun 2023, 15:23
I found that :
first create prodMap array
$prodMap = [];
// basket can contain a product several times in different basket items
// product IDs are only those of articles, selections and bundles, not of the variants and bundled products
foreach( $basket->getProducts() as $orderProduct )
            $qty = $orderProduct->getQuantity();
            $code = $orderProduct->getProductCode();
            $prodMap[$code] = ( isset( $prodMap[$code] ) ? $prodMap[$code] + $qty : $qty );
            foreach( $orderProduct->getProducts() as $prodItem ) // calculate bundled products
                $qty = $prodItem->getQuantity();
                $code = $prodItem->getProductCode();
Then access to property
$weight = 0;
$manager = \Aimeos\MShop::create( $this->context(), 'product' );
$search = $manager->filter( true )->slice( 0, count( $prodMap ) );
$expr = array(
$search->compare( '==', 'product.code', array_keys( $prodMap ) ),
            $search->getConditions(),
$search->setConditions( $search->and( $expr ) );
foreach( $manager->search( $search, ['product/property'] ) as $product )
            foreach( $product->getPropertyItems( 'package-weight' ) as $property ) {
                $weight += ( (float) $property->getValue() ) * $prodMap[$product->getCode()];
                $weight +=$vartemp;
Post by aimeos » 12 Jun 2023, 16:08
There's another option using the PropertyAdd basket plugin to add properties such as weight the the products in the basket automatically:
https://aimeos.org/docs/latest/manual/p ... ropertyadd
kdim95
Post by kdim95 » 12 Jun 2023, 18:38
If the attributes on a product change, they will change for every previous order as well.
Look at the solution that aimeos provides with the PropertyAdd plugin if you want the attributes to be saved in the order.
There are two types of product items, ordered and existing, both having their own properties.
WGSF wrote: 12 Jun 2023, 15:23 I found that :
$prodMap = [];
$weight = 0;
$expr = array(
                $weight +=$vartemp;
